It is currently Thu Aug 14, 2025 8:17 pm
 Post subject: flare fitting
PostPosted: Sat Oct 20, 2012 10:14 am
Just wondering if someone could tell me, the metal backing strip that gets welded to mudguard flange, does it go on top or under the flange/lip? I'm taking the crappy screwed on (incenti?) flares off my Rover and fitting the Cooper s type flares.
PostPosted: Sat Oct 20, 2012 11:29 am
The metal strip goes under the lip.
PostPosted: Sat Oct 20, 2012 12:59 pm
thank you, I was guessing that way but thought it best to check
PostPosted: Thu Oct 25, 2012 3:51 pm
hijacking this thread a bit,
My leyland has pretty dodgy flare backings...I had to bend them back abit at the corners for rust repairs too.
I want to flare up my mini with something more "sturdy" than the usual leyland S flares anyway, cos I reckon they are flimsy as.
Has anyone fibreglassed their own bolt on flares ?? I would do this because I feel that if I did a good job, I wouldnt mind drilling small holes into the body...
I might actually just fibreglass over the top of my leyland ones, they are cracked anyway...then at least I will have the right shape to start off with and it will "improve" their stability. I want to add bolt spaces into them somehow, like this pic
PostPosted: Thu Oct 25, 2012 6:09 pm
do you mean like the inocenti(?) ones? If so I have as set here you can have.
http://www.minispares.com/product/Class ... .aspx|Back to shop
PostPosted: Fri Oct 26, 2012 11:05 am
yeah, somethiing like that,
I would fibreglass my own so that they look a bit bigger and run smoothly down the front to the bottom of the apron, not just end abruptly like they do in that pic.
Users browsing this forum: TartanRed and 198 guests
