It is currently Mon Jul 28, 2025 3:49 am
PostPosted: Sat Oct 27, 2012 11:17 am
go to motor trimmer, our local guy had belting and machine to stitch up.
Didn't the early minis have that little plastic hook sdrewed to pillar?
PostPosted: Sat Oct 27, 2012 3:12 pm
AWOODY wrote:
The hemco belts are good got a set last month in grey look fantastic.
Any chance you could post a pic for us?
Mini's I grew up with
Slot car couch
PostPosted: Sat Oct 27, 2012 3:15 pm
Bubbacluby wrote:
68Rusty wrote:
Argh, regret, sigh! Your suggestions make too much sense, cheap tacky looking black belts it is :cry:
Does anyone know of 60’s reproductions but to todays standards?
pfft.... Keep the belts you have, if they are in good nick (photos dont always show reality). Its not like as if they will snap in accident....
My opinion and will save you a few dollars.
They are in pretty reasonable condition but mainly trying to work out why each belt are different from each other and which ones it would have had originally?
Slot car couch
PostPosted: Sat Oct 27, 2012 3:17 pm
I think after market ones are available but if not original belts probably dont need them??
I think getting parts re chromed and belts re webbed sounds like a possibilty too!
Slot car couch
PostPosted: Sat Oct 27, 2012 4:32 pm
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat Oct 27, 2012 4:49 pm
Seatbelt solutions in WA redid my seat belts and they will give you a certificate to confirm they meet Aust design rules
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Oct 27, 2012 6:51 pm
For those who don't know: Fixed seat belts, rather than inertia reels, should be worn low and tight, snug even....seatbelts extend under load....designed to do so...so, if you have em loose, you get rocketed forward in a sudden stop, then hit the belt, then it extends....
then your nose is probably already at the windscreen :shock: :idea: :!:
PostPosted: Fri Nov 09, 2012 8:23 pm
Which length of belt and stalk did you get?
I don't have any belts as a reference.
PostPosted: Sat Nov 10, 2012 7:05 am
How long did they take to do your belts Michael ?
PostPosted: Sat Nov 10, 2012 7:31 am
Klippan make exactly the right ones for mini's
PostPosted: Sat Nov 10, 2012 9:06 am
Do they do a similar colour range to hemco?
PostPosted: Sun Nov 11, 2012 8:08 am
Hemco item no. 179004 static lap sash with 1765400 600mm adjustable buckle. And there is a fixed length stalk available as well 179004sp look on there website.
Users browsing this forum: Majestic-12 [Bot] and 78 guests
