It is currently Sun Aug 17, 2025 2:50 pm
 Post subject: Which Coil
PostPosted: Mon Oct 29, 2012 5:52 pm
Hey peeps;
Was wondering if anyone knows which coil this is , 25d 29d 45d etc
And what would a replacement be for a 1973 1098cc clubman ?
Cheers. Here's a piccy hopefully it helps
Thanks bill
PostPosted: Mon Oct 29, 2012 6:25 pm
All pretty much the same coil... from memory the Cooper S got a different one.
You can use any standard coil designed for 12V (no ballast resistor), should work fine on a stock donk.
Jacob
PostPosted: Mon Oct 29, 2012 6:26 pm
The numbers you refer to are for the distributor, not the coil.
I'm not sure what the correct type of coil is, but I'm sure someone will let you know soon.
Dicko.
PostPosted: Mon Oct 29, 2012 6:30 pm
Cooper and S got an HA12 coil the rest got an LA12.
I've had a good run over the years with Australian Bosch GT40 coils; Bosch Blue ones (as used on VW etc) are also OK on a regular Mini.
Many/most new coils now come out of China so it's a bit of a lottery, whether Bosch or `Lucas'.
PostPosted: Mon Oct 29, 2012 7:25 pm
Dicko.
Oops yeah my brain crashed while trying to solve the starting problem.
Will find a picture of my distributor as i want to buy one of those electronic points systems and dont want to buy the wrong one :-)
Thanks for that its a steep learning or relearning curve with restoring a mini , so many things to do , and the manuals being rather vague doesnt help much :-) and not knowing what has be replaced over the years too.
But i will get there.
Thanks for the replies .
P.s will be back with a Dizzy pic as the one's ive put in the members section are not really good enough to see " Project Pickles "
PostPosted: Mon Oct 29, 2012 8:50 pm
Wow.. That i reckon would be the original coil from your car from factory thats crazy 8/73... your car is a 73, thats crazy. if it still works keep it on i reckon.
just a 12V coil WITHOUT a ballast resistor in it will work. I have heard good things about GT40's.
Brenton
PostPosted: Mon Oct 29, 2012 9:14 pm
Brenton
Cheers , yer i dont know how long she's been in mothballs .. but the 8/73 on the bottom of the coil surprised me , she had spark today but just wouldnt fire so im onto the carby now.
As for the Gt40's i could get one but i have been looking at the electronic points + Coil + Distributor and leads packages as i thought they would be compatible with each other part in the kit.
Edit : How can you tell if it has a ballast resistor or not ? .. sorry noob here :-)
Edit : Here's a picture of the Dizzy " hope it's enough to tell which one " .
PostPosted: Tue Oct 30, 2012 7:36 pm
If the coils aren't abused they can last a long time :)
That would be a 29D dizzy, seeing as the rest of the car looks original, probably dated 1973 as well :)
Only problem is that these dizzys can wear very badly, but see how yours looks.
edit: oh and no Oz mini had a ballast resistor, so don't worry about that.
cheers,
PostPosted: Tue Oct 30, 2012 8:05 pm
cheers,
Awesome thanks vulcan , havent pulled it out yet " well at least until i check the manual " also im pretty sure i have a spare one with all the bits i got with it.
Thanks again.
Users browsing this forum: No registered users and 323 guests
