I've been doing a search for certain queries here, but haven't gotten very far in some of these things. Mostly pretty stupid questions for sourcing parts AU vs UK.
Do the UK wipers fit a clubman?Eg: like these:
http://www.minisport.com/mini-spare-par ... S0563.html fit a 78 clubby?
Not unless you bend them at the end a bit like I did. UK LH park cars have the wiper spindles in a different spot to our Minis 1968>My indicators aren't working, I can't hear the clicking of the flasher unit. Where is it (most likely) located?Under the dash near the steering column.Been trying to sort out the wiring up the back end so i can fit in the fuel tank but indicators are no go. No clicking from the flasher so i'm assuming it's a dead unit, fuse or bad indicator stalk. I have no idea where the flasher is and the two fuses I can see in the engine bay seem to be fine, I gave them a bit of a sand as well too get a better contact. Reading the haynes manual (which wiring diagram is for my car?? why is this so difficult lol) indicates that there should be more fuses which i haven't checked?
UK rubbers in Aus car?I'm assuming the windscreen front and rear are the same.
Front is.Door to body seals?
NO, buy local. UK ones are too narrow and don't seal.Rear window seal?
Only if you get a MK1 UK one, most are wider window than ours so need cutting.
Buy local...http://www.minisport.com/mini-spare-par ... A8239.html Look rather different to
http://minisport.com.au/prod37.htmI took out the rubbers ages ago so can't remember what they look like.
I don't have the front number plate holder. Who sells them? I can't find any! Do I just make one or does the number plate mount directly to it?Try Mini King.I'm sure I'll get more questions so I'll just keep them in this thread.
Thanks always guys.
Edit, another question already.
What nuts & bolts do I need to mount the bumpers ?I'm assuming they're UNF so I'll have to order them.
1/4 UNF nuts, the studs should be in the bars already.
