It is currently Mon Jul 28, 2025 1:24 pm
PostPosted: Mon Nov 05, 2012 11:26 am
Hi all,
I have an issue with a deluxe, when lifting off throttle the car pulls to the left.
I have looked over the complete front end and have not found anything.
I have fitted new control arm bushes, caster arm bushes, ball joints still no change, the steering rack feels fine and no movement, rach is tight to the firewall, engine mounts are new but the steady bushes are a little warn and will be replaced next.
there is no clunking to it but does it all the time.
under acceleration there is no pulling, it drives straight.
anyone got any other ideas?
thanks Guys
Grant
100% Pure A Series Turbo
PostPosted: Mon Nov 05, 2012 12:07 pm
Forum Graffiti
Toe settings out?
PostPosted: Mon Nov 05, 2012 12:12 pm
Are any brakes or cables binding on one side?
PostPosted: Mon Nov 05, 2012 12:25 pm
Rack bush OK? (tug the tierod about to see)
When mine was loose it used to pull under acceleration but was fine when I backed off.
Also check the steering arms are both tight on the swivel hubs, Marlene's Deluxe did that until I tightened it up.
PostPosted: Mon Nov 05, 2012 2:11 pm
Spraycansam - It has not had a wheel alignment but string line shows it to be close and it just does not feel like toe setting.
Harley - its not a brake issue, its got s discs on it and they are all overhauld and fine
Kevin - I have not been under it and pulled/pushed on the tie rod to check the rack bush so i will look at that, its got new tie rod ends and they are tight, i do recall the lock tabs looking good on the steering arm but will check that area too.
thanks all
Grant
 Post subject: c/v
PostPosted: Mon Nov 05, 2012 2:24 pm
CV:s if worn can cause this problem, are they making any noise when u put it on full lock left or right?
mini regards
peter d
1st victorian road registered vtec mini.
PostPosted: Mon Nov 05, 2012 6:49 pm
I had one loose steering arm on the hub and it was quite scary. Would change lanes when backing off. Only just a little bit loose. Brilliant now with just the usual torque steer :shock: :shock: :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Nov 12, 2012 6:51 am
Well the good Doc has put his finger on it again, the left side steering arm had one bolt fitted and one broken off, it was a bitch to drill and easy out but got it in the end.
car now drives much better.
Thanks everyone for your thoughts.
Grant
PostPosted: Mon Nov 12, 2012 2:10 pm
Grant
f*ck.... couldn't that have gone wrong in a big way :shock:
Users browsing this forum: Andosoft and 99 guests
