It is currently Wed Aug 06, 2025 12:16 pm
 Post subject: Door Card Covering
PostPosted: Mon Nov 05, 2012 1:38 pm
Hi, I want to make some new door cards and cover them, with either Vinyl or something similar to speaker box carpet, what have people found to work best for them?
Dave
PostPosted: Mon Nov 05, 2012 4:01 pm
High heel ninja
Vynil, with a thin foam backing underneath.
Doogie
PostPosted: Mon Nov 05, 2012 4:02 pm
High heel ninja
Doogie
PostPosted: Mon Nov 05, 2012 4:06 pm
I'll add onto that: it may be an idea to try and use mdf or ply thats has a coating of something to stop it absorbing any moisture in the door and going soggy, if you can't buy it that way there will be something in a spray can.
PostPosted: Mon Nov 05, 2012 4:48 pm
I used mdf to make all new panels front & back, i also covered them in velour material they have been on the car for six years now & still look brand new.
Classic Not Plastic
PostPosted: Mon Nov 05, 2012 5:30 pm
Damn nice mini Steve....... i will be doing my doorcards myself aswell , using vinyl and going to check out clarke rubber/spotlight for some thin foam padding and some glue , making a template with the current doorcards and using Mdf/That old stuff used on back of wardrobes " cant remeber the name :-) " .
Bought a little jigsaw to hopefully cut out the handle holes etc , good fun little project me thinks.
PostPosted: Mon Nov 05, 2012 5:35 pm
thanks gents,
was going to use masonite, I think that has a coating on one side and quite rough the other so the glue for the vinyl sticks to it.
Dave
PostPosted: Mon Nov 05, 2012 6:07 pm
Corflute works well too - the stuff a lot of real estates use for heir small signs these days.
Dicko.
PostPosted: Mon Nov 05, 2012 6:12 pm
Dicko.
Damn Dicko, that sounds like a good idea
PostPosted: Mon Nov 05, 2012 6:32 pm
Dicko.
Damn i must be getting old " i am :-) " but what sort of material is Corflute , is it expensive .................. and finally where can you buy it as i would like ro have a looksee
PostPosted: Mon Nov 05, 2012 6:35 pm
It's a corugated PVC
Most sign places should sell it. I get it in Maitland from EB signs.
Dicko.
PostPosted: Mon Nov 05, 2012 7:28 pm
MiniBill wrote:
Dicko.
Just wait till election time and all the major political parties will give you as much as you want.
PostPosted: Mon Nov 05, 2012 7:31 pm
MiniBill wrote:
Dicko.
true dat
Though it will have some ugly dudes mug on it :shock: :shock:
PostPosted: Mon Nov 05, 2012 7:56 pm
Places that make computërised signs should be able to get "coreflute " for you .
PostPosted: Mon Nov 05, 2012 8:33 pm
What do estate agents do with the signs once a property is sold?
Users browsing this forum: Gambo and 93 guests
