It is currently Tue Jul 15, 2025 11:22 pm
PostPosted: Sat Oct 20, 2012 9:52 am
I have a Megajolt set up for use with a tps ( no internal map sensor in the Megajolt unit), can I use a map sensor with this Megajolt or am I stuck with tps?
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Oct 20, 2012 1:04 pm
is it megajolt v3 or v4?
either way you can purchase a conversion kit.
http://www.autosportlabs.com/-c-1_21_28.html
MJLJ V3 MAP conversion kit $24.95
MJLJ V4 MAP conversion kit $22.95
PostPosted: Sat Oct 20, 2012 1:35 pm
V4. Thanks for the information. I'm not sure I would be able to do this. How hard are these kits to install?
Could I wire an external map sensor to the Megajolt like a tps?
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Oct 20, 2012 5:29 pm
im not sure with wiring in an external map sensor but i dont see why its not posible, depending on sensor.
im again not sure on installing as i purchased mine completed, best to sign up to the autosports labs forum they are very helpful.
http://www.autosportlabs.org/index.php
EDIT > just found this>>
you can do that with the TPS ECU using an external MAP sensor and connect that up to the TPS pins. Since both TPS and MAP sensors give a 0-5V output it all works fine, just remember to change the configurator to match your new setup.
PostPosted: Sat Oct 20, 2012 7:22 pm
Could I wire an external map sensor to the Megajolt like a tps?[/quote
Excellent. Thanks for your help.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Mon Oct 29, 2012 8:38 pm
if you pay the postage, I'll solder those bits on for you - easy job... failing that, I'm about to put my megajolt on the shelf, I'll swap you if you buy me the MAP conversion kit to go with yours
PostPosted: Tue Nov 06, 2012 3:22 pm
Thanks for the offer. I'm still trying to decide between tps and map sensor. My Megajolt will be going on a twin cam Alfa with twin dellortos. All the other systems I've seen use tps. So I'll possibly stick with the tps unless someone has better advice here. I'm almost thinking I might be better with a twin spark motor from a Alfa 75.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
