It is currently Mon Jul 28, 2025 5:18 pm
 Post subject: Seat Brackets
PostPosted: Mon Aug 06, 2012 3:47 pm
I have two different types of seat brackets and I was wondering what models they were off.
I want to modify one set, but I want to make sure they aren't rare or anything.
My guess is that the longer ones are the stock 850 ones , and the other are later model ones...
Correct??
Image[/img]
Dusk Blue
1964 850
PostPosted: Mon Aug 06, 2012 3:51 pm
Stock Oz made 850 seat brackets only had 1 hole and were rivetted onto the seat, they had no bolts & wingnuts.
My `guess' is the RH one in pic is Morris Cooper up to 1964, and the LH one is later.
PostPosted: Mon Aug 06, 2012 11:25 pm
Location: MinisintheGong [Somewhere on the South Coast]
The red one on the LHS was used on the later models.
I cannot comment on the black one - foreign to me, and knowing Kevin's prowess I'd run with his comment until proven otherwise. Or maybe use the parts book?
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Mon Aug 06, 2012 11:42 pm
Black on is bog stocko rover, used early 80s right through to end of production.
Red is aussie and early car up to 77.
PostPosted: Tue Aug 07, 2012 6:13 pm
Yep I agree with Harley.
PostPosted: Tue Aug 07, 2012 7:26 pm
Ok , thanks guys :D
Dusk Blue
1964 850
PostPosted: Fri Nov 09, 2012 8:53 pm
Does anyone know the bolt size to mount seat brackets to the crossmember??
And if you do I'm very surprised..!
PostPosted: Fri Nov 09, 2012 9:14 pm
1/4" UNF, 1/2 or 3/4" long.
Put a big washer under the head as the holes in the bracket are slotted.
PostPosted: Sat Nov 10, 2012 7:46 am
The black one looks like the one fitted to the Elvis Presley special edition, only 6 made........... :lol:
On the more serious side, another good idea is to put bracket in position on cross member and cut round bracket and remove that little bit of carpet under it. Lets you tighten bolts properly without distorting cross member or nuts cracking out with 'larger' persons.
PostPosted: Sat Nov 10, 2012 9:07 am
Cheers harley
PostPosted: Sat Nov 10, 2012 2:30 pm
Ive got the left one in my 77...
Never seen the right one.
1977 Leyland Mini Van - Sold
Users browsing this forum: Bing [Bot] and 77 guests
