It is currently Tue Jul 29, 2025 6:27 pm
PostPosted: Sun Nov 11, 2012 5:12 pm
My friends I am at my wits end... I'm currently installing a disc brake setup on the front and have come to a big road block.
The passenger side was completely set up and torqued with a wheel on and everything's sweet.
The drivers side is buggered. I had everything set up and went to torque the hub nut, and after just a bit of tightening it has a spot when it rotates that it completely sticks and essentially seizes up.
I thought it was the drive flange a bit off, so I disassembled it all and used a heap of tools to make sure it was flush. No luck. I then disassembled the good side and tested the rotor and drive flange. No luck. Not the drive flange or rotors.
Next step I thought maybe the wheel bearings looked a bit off (timken taper). So I got a socket and banged it to make sure it was flush. Tested again and no luck. I then used the passenger hub on the driver side. Still no luck!
I have no idea what to do now. The bearings and rotors aren't the issue.
I have pot joints. All the balls are inside and rotate freely without the hub nut on in the set up.
Does anyone have any recommendations at what to do???
I didn't use a new circlip on the CV joints is the only thing more I can add.
It's been off the road now for 8 weeks and I've missed some great driving weather!!
Seriously appreciate absolutely anything you can add.
PostPosted: Sun Nov 11, 2012 5:56 pm
Are the hubs/uprights new or 2nd hand?
Same for the drive flanges.
if you don't tighten the CV nut all the way does it spin freely?
cheers,
Jacob
PostPosted: Sun Nov 11, 2012 6:11 pm
Is the inside of the disc bell catching on the swivel hub?
PostPosted: Sun Nov 11, 2012 6:15 pm
Is one of the bearing cups not fully seated in the hub??
Cheers Shane
PostPosted: Sun Nov 11, 2012 6:17 pm
Every component is brand new and came together in a kit.
I don't believe they are catching, as the rotor and hub setup that spun freely on the other side also would not spin on this.
It spins perfectly when done up by hand. Once the rattle gun gets on its game over.
PostPosted: Sun Nov 11, 2012 6:56 pm
does it have spacer between bearings, some do, some have it built in to bearing. If you slowly increase tension on axle nut does it just lock as in cv joint or drive flange touching, os does it get progressivly harder to turn. As for everything being new, that's even more reason it may be machined wrong. You can test bearing adjustment by puting a big bolt/washers, in place of axle /flange, tighten and see what happens.
PostPosted: Sun Nov 11, 2012 7:04 pm
Yep its got the spacer, it's quite loose when I installed it?
Nice tip about the bolt.
It gets progressively harder to turn as I tighten the nut, eventually locking into place, but only at one point.
PostPosted: Sun Nov 11, 2012 7:11 pm
Sounds like the spacer is too thin or the hub has been machined a bit thick... so when you torque it up it's preloading the bearings waaaay too much and hence it locks-up.
Jacob
PostPosted: Sun Nov 11, 2012 7:23 pm
Sounds very plausible;
however confused as to why 1 set of bearings and hub that worked fine would also not work on on it. Maybe some other fitting problems putting the opposite side hubs on..
PostPosted: Sun Nov 11, 2012 7:53 pm
Are the spacers matched to their bearing kits?
I don't believe they got separated during the build but they did sit on my bench for few days... Who knows!
Can you get the seals off without ruining them to swap them around?
PostPosted: Sun Nov 11, 2012 7:59 pm
Give Ash some flowers Nick .
I don't think the spacers are matched to each bearing but they do end up matched once they have been linished depending on the amount of play in the bearings they have when torqued up.
If you haven't linished the spacers, I don't think they are matched - or at least mine didn't look like they were.
If you are careful you should be able to get the seals out without damaging them. I think I have in the past and they have come out pretty good. Generally I just reef them out to remove them because I have no intention of re-use.
I think you need to disassemble and start from scratch. Is the problem side the first or the second side that you did upon initially assembly?
PostPosted: Sun Nov 11, 2012 8:41 pm
ok,,, 2 things i`d check before you rip all your hair out
one--> are the drive flange set-screws too long & the tail of them button-ing into the snout of the hub where the outer wheel brg grease seal is???
& two--> is there a bit/bulge of your steering arm protruding out-ward of the face of the swivel hub just enough to contact the disc-rotor?
PostPosted: Mon Nov 12, 2012 7:42 am
Mine were matched with serial numbers etched on each. Sorry I can't tell you the brand. However the fact they only bind at one point sounds odd.
PostPosted: Mon Nov 12, 2012 2:28 pm
Are they Timken bearings, or noname ones? and where were the new swivel hubs bought from (some are made in the far east now).
As I said in PM, bring over and I'll suss the problem out.
PostPosted: Mon Nov 12, 2012 4:32 pm
The rooted side bearing spacer has almost a 1mm gap between bearings, the good side is minimal.
Mean anything to anyone?
I gonna go give swapping the spacers or even the bearings over.
Users browsing this forum: andrew9 and 111 guests
