It is currently Wed Jul 30, 2025 6:45 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Mon Nov 12, 2012 5:17 pm
are you sure the cones have been punched in as far as they`re meant to go? --> As in hard up against the inside shoulder
PostPosted: Mon Nov 12, 2012 7:30 pm
Mate I think that's what must be the issue.
I also thank you for making me double check the rotor screws as the drive flange screws were protruding abiut a mil, which I will grind down.
PostPosted: Tue Nov 13, 2012 10:11 am
It's fixed!
Really appreciate all your help people! Pulled the bearing seals off and gave the outer races another good beating and the spacer became noticeably tighter!
I got scared as I put the good side back together and that had the same problem! But I swapped the rotors and if fixed it..... Both spin freeeee.
Users browsing this forum: Bing [Bot] and 91 guests
