It is currently Thu Aug 14, 2025 5:47 am
PostPosted: Thu Nov 22, 2012 8:17 am
I finally got my mini back on the road after 5 years. For some reason when I'm at the lights, she idles and then stops. It's a mini rover import auto. It has been in 2 times in the last 3days to the mechanic but still I'm having this problem and I can't keep paying the mechanic money for not fixing it. I need help?
PostPosted: Thu Nov 22, 2012 8:31 am
Got more information at all? Carbies, ignition, engine age?
PostPosted: Thu Nov 22, 2012 8:42 am
It's a 1990 model but I think the engine is 88-89 there abouts. Single carbi, runs on unleaded and has a catalytic converter on it. I really don't know to much about it. It was a Japanese import and it had to be an auto so the wife could drive it. Cheers!
PostPosted: Thu Nov 22, 2012 8:49 am
Start with the simple stuff and make sure the mechanics checked it out...
Points and condensor and pretty much everything inside the distributor.
Carby bits and pieces... Mixture, air filter, idle speed.
Will it keep going if you rev it a bit at the lights or will it die no matter what once you stop?
PostPosted: Thu Nov 22, 2012 10:54 am
Enough oil in the carby?
Had this problem with my recent countryman restoration, would run fine but as soon as you stopped it would cut out. Turned out to be the oil damper plug in the top of the carb didnt have a tiny hole in it, took us hours of swapping carb bits around until we found the problem.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Nov 22, 2012 11:41 am
If I rev it at the lights it will keep going, but once I take my foot off the gas when stationary it will stop. I was told by the mechanic that it was idling at 1000rpm which should be fine but I think it drops to around 600rpm when stationary. Then sputters out and stops.
PostPosted: Thu Nov 22, 2012 12:16 pm
Mods rock!
sounds like the butterfly in the carb is worn or not seating properly. Could also be the vac advance on the dissy sticking or getting some vac at idle (when it shouldn't). Has the mechanic check the fuel level in the float bowl?
PostPosted: Thu Nov 22, 2012 7:27 pm
Killkeny.
Just a "wild Card". Are you holding the brake on. I had a car many years back where the brake booster vacume diaphram leaked. Everytime I held the brake (at lights, LOL) it stalled.
Alex
PostPosted: Thu Nov 22, 2012 8:43 pm
clean maybe the su pot . where the needle goes up and down. mine was somehow getting stuck at some point and would stall when i got to idle.
worth a try
Users browsing this forum: Bing [Bot] and 290 guests
