It is currently Fri Aug 15, 2025 1:15 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 24, 2012 2:33 pm
Give Wombat a buzz , he can fix you up with one , he used to do a conversion on them .
PostPosted: Sat Nov 24, 2012 3:46 pm
What did he convert them to? Actually I don't even really know what it does.
Edit: thanks for the link in the pm. I know know what it does and how it works. I might give mine a good clean and see if that gives it another 40 odd years of life.
Thanks Neil!!
PostPosted: Sat Nov 24, 2012 5:37 pm
The problem with the originals is they use bimetal strip vibrator technology, similar to how a flasher can works but @ much higher frequency.
Over time the contacts inside get grotty and it doesn't work as originally.
Mine was interesting- the faster I drove, the lower the fuel gauge would read, then when you stopped @ the lights you could see the gauge come back up.
But if I ran it up on stands in the garage at 80 or 90 kmh or more it was fine. :shock: :P It was road/body vibes upsetting it.
So, I fitted a Wombat electronic 10V special and it's been fine ever since.
