It is currently Tue Aug 19, 2025 11:11 am
PostPosted: Sun Nov 25, 2012 6:55 pm
Hey all, so im assuming its pretty damn bad. Perhaps a blown head/headgasket?
As I stated, misfiring when cold for about 20 seconds... as in its firing on only a couple of cylinders then they all kick in.
Today the car started but after being left off for twenty minutes it wouldnt start at all.
Under the oil cap there is milky sludge. What are the possible causes? Head gasket?
Recently serviced with gulf western by minisport, new radiator with coolant recently.
Thanks for your help!
1973 Leyland mini - reconditioned 1100, good nic overall!
PostPosted: Sun Nov 25, 2012 7:18 pm
How did the exhaust look? Lots of white smoke?
Try dropping the oil to see if its milky.
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sun Nov 25, 2012 8:45 pm
yeah white smoke out the exhaust.
oil on the dipstick wasnt milky but ill drop it tomorrow to see if its milky.
PostPosted: Sun Nov 25, 2012 9:01 pm
If it’s just the gasket that’s gone its shouldn't be too big a deal.
Under head cam makes it nice and easy :wink:
WD40'll fix it!
PostPosted: Sun Nov 25, 2012 9:18 pm
ah cool, hopefully its indeed just the gasket. Pretty busy recently so taking it to minisport in the morning.
Would the gasket alone make it not start due to wet pistons/spark plugs?
Thanks for the help buddy ;)
PostPosted: Tue Nov 27, 2012 7:06 pm
Yeah, was the gasket, but it had overheated at one point by the previous owners.
The head was stripped, sandblasted, crack tested, exhaust seats cut, welded corroded water ways.. new valve springs.. basically a small rebuild
There is a slight ticking coming from the engine when warm now, will have to investigate this.
