It is currently Thu Aug 07, 2025 9:40 am
 Post subject: Seat questions
PostPosted: Tue Nov 27, 2012 4:20 pm
Good afternoon all
The seats in my mini (and the door cards, now that I think of it) are a little worse for wear. The back seat feels fine, but there's a bit of a rip in the dot-cloth. The front seats are under covers, but i know they are FILTHY, and they seem to be caving in when I sit on them. Old foam I suppose.
So my questions are:
1. I'm going to give them a clean first and see how they come up. Product suggestions? I have the dot-cloth inserts, tips on cleaning this?
2. Can the foam be redone without having to re-trim the outside? Or, any other ideas as to why the seats feel like they have lost their pizzaz?
3. If i do need to retrim the seats, the dot cloth is supposed to be hen's teeth, isn't it? Has anyone had any luck with reproduction stuff?
Cheers!
78 Leyland Mini - Prince
PostPosted: Tue Nov 27, 2012 4:38 pm
have a look at the rubber diafram under the seat
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Nov 27, 2012 5:49 pm
+1 for checking the rubber diapham underneath.
If they are broken the seat will feel saggy.
If you need some i have 2 brand new ones sitting here. :wink:
Dusk Blue
1964 850
PostPosted: Tue Nov 27, 2012 6:40 pm
So are there only the rubber diaphragm ones available now? Mine have a wire spring base?
PostPosted: Tue Nov 27, 2012 6:53 pm
[quote="womble99"]So are there only the rubber diaphragm ones available now? Mine have a wire spring base?[/quo
you must have an early one :D
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Nov 27, 2012 7:05 pm
Can't be that early, I am led to believe they are clubman seats? ie have the catch on the rear and the floor rail?? :?
PostPosted: Tue Nov 27, 2012 8:14 pm
Are they both the spring type? Surely someone could have repaired the seat with a sprung base at some stage. Not to mention it wasn't uncommon for them to use what was availiable during manufacturing.
PostPosted: Wed Nov 28, 2012 1:36 pm
The Mini King
They did at one stage have the spring type base, but changed back to the rubber type
after a short period of time, The spring type base can be obtained, However I would convert to the rubber type
PostPosted: Fri Nov 30, 2012 3:57 pm
Correct. From memory (not reliable...) I'm pretty sure they are rubber, not springs. I'll check them out, cheers all!
