It is currently Fri Jul 11, 2025 11:54 pm
 Post subject: r1 mini
PostPosted: Tue Nov 27, 2012 5:17 pm
http://www.speedhunters.com/2012/11/r1-powered-mini/
PostPosted: Tue Nov 27, 2012 5:45 pm
Is it just me, or does that custom subframe look not terribly strong.... :?
I am no expert, but i thought you needed a stronger subframe for a flip front too.
Dusk Blue
1964 850
PostPosted: Tue Nov 27, 2012 6:40 pm
Looks like it uses the engine to gain its strength.. Little bit of flex in a race car could help it too
PostPosted: Tue Nov 27, 2012 6:45 pm
It looks like an extended front. I like it.
PostPosted: Tue Nov 27, 2012 8:17 pm
The engine was designed as a stressed member when it was installed in the bike. No reason why you couldn't reproduce that in a mini provided you don't exceed the same loading applied when it was in a bike.
PostPosted: Wed Nov 28, 2012 11:45 am
Stressed member is all well and good
But the subframe looks like it's made out of 12mm round stock.
That's a bit different to 30x3 Structural CHS that everyone else uses!
You're so square
Baby I don't care
PostPosted: Wed Nov 28, 2012 12:52 pm
Mini power unit weighs about 150kgs
R1 power unit weighs 75kgs
tooth-picks would almost suffice :-)
That`s a joke btw :-)
PostPosted: Wed Nov 28, 2012 4:51 pm
Dang it! I just ordered a bulk lot of toothpicks off eBay!
Oh well...
 Post subject: Drive!!
PostPosted: Wed Nov 28, 2012 11:01 pm
The one thing I want to see, is the one thing I can't. How does he transfer drive from the output shaft of the box to the wheels? AAArrrggghhh.
PostPosted: Thu Nov 29, 2012 8:53 am
He will have a diff "cradle" mounted under the engine,,, he has his engine mounted far higher in the car than mine so his chain will run down-hill to his diff,,, mine runs backwards cause my engine if lower & more forward than his
it`s not to hard really,,, i made my own but you can buy them
here`s my diff & cradle, LSD with sprocket & covered/sealed with an orange juice tin & a couple of o-rings,,, it has a drain/filler plug too :-)
PostPosted: Thu Nov 29, 2012 1:40 pm
This space for rent
Hehehe.. is that the cork I can see held in with a cable tie? :lol:
PostPosted: Sun Dec 23, 2012 9:22 pm
hee hee,,, yeah its a little rubber/plastic plug from something i found ...& fits good so the zip-tie holds it in & works a treat,,, no leaks & i can slide the ziptie to the side, pull the plug roll the buggy forward a bit aligning the oil drain tray up & drain the old crap out ...re-fill with new crap... & re-plug with the bung-thingy & slip the same old ziptie back over it :-) job done :-) easy-peasy :-)
PostPosted: Tue Dec 25, 2012 7:55 am
Matt, you are the master of innovation my friend - simple, but effective.
Merry Xmas bro!!
Tricky
