It is currently Mon Jul 21, 2025 12:36 pm
 Post subject: Caliper refurb
PostPosted: Tue Nov 27, 2012 6:43 pm
I have a set of kits to put through my calipers before I put the 8.4's back onto my mini, however before I do that i was thinking they could do with a clean up and a paint.
What is the best method to clean em up? Good scrub in the parts washer, bead blast em???? is there anything I shouldn't do?
Never played with brakes before (other than pad change) so I don't want to stuff em up :D
PostPosted: Tue Nov 27, 2012 8:33 pm
I wire brushed mine (S brakes), washed with metho, fitted new seal kits, THEN painted them with VHT yellow caliper paint.
They look good but the paint is very thin, not much solids in it, needs lots of coats. Red or black cover much better.
Note the 2x bent bits of 1/8" welding electrode, much stronger then the POS Chinese 3mm split pins everybody sells now (see sample sitting below).
I lost a pad once because the damned pins broke/wore through.
PostPosted: Tue Nov 27, 2012 8:36 pm
Yep the VHT red is the plan, if i can ever find someone with it in stock..........
 Post subject: Being yellow...
PostPosted: Wed Nov 28, 2012 12:48 pm
Being painted Yellow does the Car stop better ?
"Let us remove your "SHORTS"
 Post subject: Re: Being yellow...
PostPosted: Wed Nov 28, 2012 1:17 pm
Ask Evan, (cooper matrikon) they are on Barney. :P
PostPosted: Wed Nov 28, 2012 7:59 pm
I have yellow calipers and they give me an extra 25kw atw.
8)
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Thu Dec 06, 2012 8:22 pm
ok next really dumb question about brakes. I have been looking at YouTube for vids on pulling calipers apart etc for refurb but all calipers i see are singles? (piston on one side only)
What do you call the ones we have with two pistons?
Standing by for probably an obvious answer :oops: :oops: :oops:
CJ
PostPosted: Thu Dec 06, 2012 8:30 pm
You'd never guess, but hey, they're twin-piston calipers! :)
PostPosted: Thu Dec 06, 2012 8:50 pm
See i told ya I was expecting an obvious answer :roll: pity it didn't help with the YouTube search though :? still only finding single piston jobbies.
Can't see there could be much difference in the refurb between the two though? One way to find out :lol:
PostPosted: Thu Dec 06, 2012 9:20 pm
I've been told - but not done it myself......
I'm told that you should not split the callipers. The fluid flow from one half to the other is sealed by an unusual square sectioned O ring.
Scuttlebutt is that these are somewhat rare (never looked myself).
Cheers, Ian
PostPosted: Thu Dec 06, 2012 9:44 pm
Cooper and cooper S calipers are also sealed by a `square section O-ring'.
Only the size of it varies.
IMO only masochists would rebuild calipers without splitting them.. :lol:
PostPosted: Fri Dec 07, 2012 2:20 am
http://www.minis.com.au/minis/catalog/product_info.php?cPath=31&products_id=604
Caliper seals are available new for $5.
Worth it i'd say.
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Sun Dec 09, 2012 7:23 pm
Hmm well i have cleaned and repainted the calipers, next to pull the pistons out and fit the new kit. Slight problem, I can't get the pistons to budge :(
Looking on the web the recommendation is to apply air to blow them out, only problem is I don't have a compressor. best I could find was 50psi from a tyre inflator but it didn't budge em.
Is there another way to get them out without connecting it to the car?
PostPosted: Sun Dec 09, 2012 7:34 pm
Grease gun... way more pressure than an airline.
:wink:
PostPosted: Sun Dec 09, 2012 8:02 pm
:wink:
lol, then you just have to clean the grease out :)
Users browsing this forum: 68+86auto, Bing [Bot] and 103 guests
