It is currently Fri Jul 18, 2025 6:04 pm
 Post subject: Alternator Bearings
PostPosted: Thu Dec 13, 2012 8:46 am
Ok so the bearings on my alternator are starting to make noise and although I still seem to have 14 volts across the terminals, I am worried about it all failing on me.
Is it better to replace just the bearings or given its age, should I just rip the lot out and replace it with something like this:
http://www.minisport.com.au/prod332.htm
PostPosted: Thu Dec 13, 2012 8:50 am
Seems a tad pricey??? How much are bearings?
PostPosted: Thu Dec 13, 2012 8:55 am
Pricey? that's how much they all cost. What were you thinking they cost? $50?
Good Bosch ones are $250
PostPosted: Thu Dec 13, 2012 9:03 am
I thought the price was fair... Anyhow I can supply bearings for under $10ea if you want (2 required per alternator)
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
Minisport for all your mini parts
PostPosted: Thu Dec 13, 2012 9:33 am
Hey Andrew... sorry it wasnt meant to be a discussion on price... :roll:
I was more wondering if in people's opinion it was worth replacing the bearings now (and running the risk that the rest of the bits in the alternator would need servicing / replacing down the track anyway) or if I should just bite the bullet and replace the whole unit now with a new one.....
PostPosted: Thu Dec 13, 2012 10:07 am
Sorry guys...I meant it in the context of, if the only thing wrong with the alternator was the bearings then why replace the whole thing when as it turns out bearings are 1/8th the cost.
PostPosted: Thu Dec 13, 2012 12:21 pm
hence my question ... I dont like band-aid fixes. If it is just going to have to be replaced down the track, I may as well just replace it now...
PostPosted: Thu Dec 13, 2012 12:24 pm
This space for rent
I don't see how replacing the bearings is a band-aid fix. There's not many moving / wearing parts in an alternator, so if the rest of it's OK then replace the bearings and get another 20 years out of it ;)
PostPosted: Thu Dec 13, 2012 12:27 pm
Geeez tough crowd.......What SGC said!
 Post subject: Replace bearings
PostPosted: Thu Dec 13, 2012 12:46 pm
Hi
Whatever is decided , be safe and clear when checking.
In a non BMC car , i was investigating a similar noise , and due to issues of hearing and seeing between driver and repairer, i ended up losing the top of my finger in alternator pulley.
:oops:
The good news is the bearings were replaced and it kept going for another 10 years to my knowledge
PostPosted: Thu Dec 13, 2012 3:26 pm
Changing the rear bearing on most Lucas alternators (the ones with a plastic end cover) is not a fun job.
You need to de-solder the slip ring on the end of the armature, and remove it undamaged before you can get the rear bearing off.
Then, you have to re-solder it on completion.
I bet the pulley is worn U-shaped too... :roll:
By the time you muck about I'd just buy a new one. :wink:
 Post subject: Good price
PostPosted: Thu Dec 13, 2012 5:46 pm
Sounds reasonable to me. Reconditioning an original Lucas one may cost more.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 110 guests
