It is currently Sat Jul 19, 2025 1:21 pm
 Post subject: New dampers
PostPosted: Wed Dec 12, 2012 8:04 am
Hi all,
I recently bought a set of these:
http://www.minisport.com.au/prod3.htm
They've just arrived, and they look great. However, I'm a little confused. I haven't had much experience with new dampers, but I thought I would be able to move them by hand. But they're stuck solid! The old ones I can compress/decompress fine, and even the ones on my hilux can be moved easy by hand. Is this because they're new? How do I get them to move!
PostPosted: Wed Dec 12, 2012 8:59 am
they`re a gas charged shock.,.. so they will be a little harder than a std shock
you`ll need some decent force to get them to move yes
PostPosted: Wed Dec 12, 2012 12:00 pm
Do gas shocks still need priming?
PostPosted: Wed Dec 12, 2012 12:23 pm
The term `gas shocks' is a misnomer.
They are charged with low pressure nitrogen rather than having air in there, but they are still a fluid damper, using shocky oil.
They will prime themselves in use once mounted vertically.
PostPosted: Wed Dec 12, 2012 2:23 pm
just curious - what is the part number for the fronts?
PostPosted: Wed Dec 12, 2012 3:46 pm
The ad said
"they are self adjusting (much the same as the monroe sensortrack"
How does that work ?
PostPosted: Wed Dec 12, 2012 4:03 pm
I've often wondered what they meant by that. Seems like one of those doesn't-really-mean-much advertising things (there's no permeate in our milk!). I bought them because they had good reviews on this forum.
I can check the front part number, but I imagine it is 552018, as that's what they are here: http://www.minisport.com.au/prod826.htm
PostPosted: Wed Dec 12, 2012 6:35 pm
It's to do with multi valved piston inside. Basicly if you push them quick, i.e. drop car out second story window, the shocks react by being stiff. If you just go over whoop de do's slow they remain soft.
PostPosted: Wed Dec 12, 2012 9:02 pm
Not the most thrilling of videos to watch, but it explains the gas adjust nicely.
http://www.youtube.com/watch?v=J_V4JAIOF2c
PostPosted: Thu Dec 13, 2012 7:07 am
The problem I have is, if I can't get them to move it's going to be a lot more difficult to attach them to the car!
PostPosted: Fri Dec 14, 2012 5:47 pm
Some shocks come with a metal clip holding the shocks compressed to make them smaller for shipping. They will have a clip that goes around the shaft and locks under the collar. Or, they could just be really stiff!
PostPosted: Fri Dec 14, 2012 5:55 pm
Trolley jack under the hub does the trick for stiff gas shockies.
PostPosted: Fri Dec 14, 2012 8:32 pm
this one is really interesting - he shows a transparent damper at the emd and very clearly demonstrates what the gas pressurisation does
watch to the end
http://www.youtube.com/watch?v=W4ZZYqRVzLc
PostPosted: Fri Dec 14, 2012 9:42 pm
I've just fitted these rear shocks a few days ago, I could not move them by hand, but once I fitted the bottom end of the shock on the pin of the swing arm, I was able to use my body weight to compress the shock and keep in compressed enough to swing it up and around and fit the top of the shock into the wheel arch mount.
Caleb
