It is currently Sat Jul 26, 2025 11:49 am
 Post subject: splutters at high RPM
PostPosted: Sun Dec 16, 2012 5:27 pm
My mini with it's A+ 1275 carby engine has developed a miss around 5000rpm. The revs climb strongly until it hits that area then it dies, if I change up a gear the engine keeps going fine until I hit 5000rpm again.
Now I haven't tuned the engine in a long time so is it safe to assume it's just out of tune or could it be a semi blocked fueling system of some sort?
PostPosted: Sun Dec 16, 2012 6:09 pm
What sort of pump and carby have you got?
PostPosted: Sun Dec 16, 2012 6:21 pm
If you haven't tuned it for a fair while , i'd start with the basics , plugs , points , ( especially correct gap setting ) timing , then carbie , Plus changing the fuel filter can't hurt .
Change one thing at a time , otherwise you won't really know what fixed it .
PostPosted: Sun Dec 16, 2012 6:47 pm
Check your vacuum advance hose for kinks too.
I've had that happen before.
 Post subject: Misfire @5000 RPM
PostPosted: Sun Dec 16, 2012 6:53 pm
I suggest you stick to the speed limit especially at this time of year. What speed does this car do at 5000 RPM? Perhaps you need a higher ratio Differential so you don't have to rev it so hard. Otherwise try another set of plugs.
"Let us remove your "SHORTS"
 Post subject: Re: Misfire @5000 RPM
PostPosted: Sun Dec 16, 2012 8:14 pm
Electric pump and a HIF4 carby.
goodie wrote:
If you haven't tuned it for a fair while , i'd start with the basics , plugs , points , (especially correct gap setting) timing , then carbie, Plus changing the fuel filter can't hurt .
Change one thing at a time, otherwise you won't really know what fixed it .
The dizzy is the std electric item that came on the Rover A+ motor so no points to worry about.
Well it all depends on what gear your in as to how fast your travelling at 5000rpm, I hit that pretty much every time I change gears, when do you change gears?
PostPosted: Mon Dec 17, 2012 10:36 am
Check your dissy cap and points, leads, spark plugs, the usual and common culprit of high rev splutter. Next is probably carby, when was it last serviced?
I change mine at 3500rpm most of the time, honest Officer 8)
Lillee - 1969 Morris Mini K
PostPosted: Mon Dec 17, 2012 12:00 pm
If you held the revs at the point of splutter for a short while,,, then do a spark plug check,,, see what that tells you
Also, my guess is coil
Just a guess tho :-) i really have no idea :-)
Users browsing this forum: stewartp and 87 guests
