It is currently Mon Jul 21, 2025 4:53 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Dec 19, 2012 6:56 am
Mick wrote:
braad wrote:
Hey guys, i have another question for all you 10x6 mamba owners.
On midlandwheels website they say the 10x6 need modifications to fit. I'm assuming they're meaning wheel arch cutting? Or are they referring to the flares? anyone run into troubles?
I did have problems with the outer corners of the wheels fouling the flairs supports close to lock at a standard height. This will be what they mean.
Ah ok fair enough. That'll be a pain in the ass but a necessary evil
meeni wrote:
Yeah you can clearly see the rotor vents are clear of the wheel so the offset is big.. Meh
Well at least you wont have to worry about brake ducting!
1963 850 - laid up
PostPosted: Thu Dec 20, 2012 11:03 pm
Here is what Midland's sent me. It confirms what smac quotes, but I finished up with 'sticky outty' wheels. And my tape measure still reads 100mm from disc face to outer rim. The only problem you may strike is rubbing on the front wing on lock, if lower than standard.
Dalmeny
PostPosted: Wed Dec 26, 2012 9:26 pm
Heads up for all those who are thinking of buying wheels from midlands soon, they have a 20% discount until the 31st december!
Remember when ordering or making a quote up that you do the wheels and tyres separately otherwise you cant do the 20% discount. That is because when doing a wheels and tyre package together they discount the tyres by a bit. By adding the items separately you can apply the 20% to everything and save a lot more
I'll be ordering mine soon....my main problem is mambas or minator
1963 850 - laid up
Users browsing this forum: Goldbrocade_62 and 74 guests
