It is currently Thu Jul 31, 2025 5:33 am
 Post subject: DCOE 40 Float Level
PostPosted: Sat Jan 05, 2013 12:23 pm
I think I've found the float level settings for every other car except a mini!
Does anyone have any info or links?
Car goes sweet up to 4000 rpm and then seems to get starved of fuel... and so far I've just used a generic setting from "How to Powertune Webers", so want something a bit more accurate to hopefully solve this.
PS Its a spiced up little 1098
Thankssss!
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Sat Jan 05, 2013 12:52 pm
The number in that Weber book for a DCOE is correct, so is the one it gives for the Dellorto DHLA.
PostPosted: Sat Jan 05, 2013 12:55 pm
You mean the one with the "how to set the float level" area, not a specific car at the back of the book?
Was 12mm closed (standard) and 26mm open. Was far longer stroke than I had set up originally when it ran well is all. (I don't know what I ran before, I can't find the info!)
1975 Clubman
PostPosted: Sat Jan 05, 2013 1:13 pm
p49.. read it.
It is 7.5mm (gasket vertical) and 15mm droop (gasket horizontal) for a Weber DCOE.
PostPosted: Sat Jan 05, 2013 2:05 pm
Yep got that but 12-26mm for the plastic floats next page.
I've seen various listings for different engines having different float levels is all
1975 Clubman
PostPosted: Sat Jan 05, 2013 2:22 pm
does it have a plastic float? most Webers here have brass ones.
My Dellorto has plastic though.
PostPosted: Sat Jan 05, 2013 2:36 pm
Yep plastic-new model 8)
1975 Clubman
