It is currently Thu Aug 07, 2025 1:33 pm
PostPosted: Sun Jan 06, 2013 11:51 pm
Here is a snap... No expert but I think this is cream crackered! Lol
Just checking I am correct and not that this is usual on the bush side and not to worry....
PostPosted: Mon Jan 07, 2013 12:48 am
That will polish out*
*unless its a new aftermarket one that they forgot to harden.
PostPosted: Mon Jan 07, 2013 12:54 am
Looks original 1965!
 Post subject: Worn.
PostPosted: Mon Jan 07, 2013 6:48 am
With that much wear I am sure it will give you unwanted rear wheel steer.
"Let us remove your "SHORTS"
PostPosted: Mon Jan 07, 2013 7:53 am
Check the hardness of the new ones, if you can file the corner of the straight part it's soft = NFG.
Has to be hard (61HRC or better) or the rollers will chew it up.
PostPosted: Mon Jan 07, 2013 10:58 am
It was wobble and play free..... But I will get some new ones....
