It is currently Tue Jul 22, 2025 6:16 pm
 Post subject: Rover temp gauge
PostPosted: Thu Jan 10, 2013 3:24 pm
These run on 12 volts or do they need a stabilizer ???
PostPosted: Thu Jan 10, 2013 4:46 pm
Rover instruments do not have a voltage regulator "Externally" like the earlier ones . But looking at the printed Circuits there is a link between the Fuel and Temp Gauges which gives me the impression that there might be a Voltage stabilizer built in to the fuel Gauge like most modern cars. I could be wrong. If you have a cluster out of it's place and you can access the point with a Volt meter you can test what voltage you get at this link with the ignition turned on. If it is less than 12 Volts then there is a built in stabilizer internally.
"Let us remove your "SHORTS"
PostPosted: Thu Jan 10, 2013 5:02 pm
I'm trying to put a rover 2 clock cluster into a clubman harness
PostPosted: Thu Jan 10, 2013 5:25 pm
they have the stabiliser build in so you can connect them right to your 12V source
Rover 214 atm ....
PostPosted: Thu Jan 10, 2013 6:32 pm
What could be wrong if it works but is reading incorrectly, reads full when full but empty when there is still half a tank.
PostPosted: Thu Jan 10, 2013 6:54 pm
Fuel gauge works but is not accurate and temp does work at all
PostPosted: Thu Jan 10, 2013 7:13 pm
thats a very common problem, even worse with the latest MPi Rover. thats why they made the sender adjustable and after they didn't adjust it properly from the factory the issued a tech bulletin.
don't know it this helps with your minis.
Rover 214 atm ....
PostPosted: Fri Jan 11, 2013 3:51 am
I have a 97 Japanese SPi - how do you adjust the sender?
PostPosted: Fri Jan 11, 2013 8:25 pm
hope you don't mind the german language
http://allbrit.de/downloads/BULLETINS/Tankanzeige.pdf
Rover 214 atm ....
 Post subject: Grerman?
PostPosted: Sat Jan 12, 2013 1:50 pm
Das ist alles klar, mein Deutsche is gans gut noch Klas. Danke..
PostPosted: Sun Jan 13, 2013 7:59 am
freut mich wenns hilft
Rover 214 atm ....
