It is currently Fri Jul 25, 2025 1:06 pm
 Post subject: Point problems
PostPosted: Fri Jan 11, 2013 7:14 am
Hopefully someone can lead me in the right direction, I was having troubles with the points in my 76 Leyland (998). After replacing with a new set we were still having problems - point gap would be set, car would be ok and then once turned off and restarted, the gap would appear to close causing issues. So a whole new dizzy was purchased and installed and it seems that the gap is changing again! Can anyone tell me what can be causing this and what on earth we have either done wrong or what we can do to fix??? :)
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Fri Jan 11, 2013 7:58 am
Points and condensers are coming from the far east now not made in UK.
Quality is not there.
My suggestion- bin both and fit an electronic module inside the dizzy.
Can buy these from most Mini parts shops here, or PM `convertible mini', or bring in from UK.
eg-
http://www.simonbbc.com/bundle-deals/ig ... une-up-kit
If you don't need a cap because yours is new you can buy a kit without it.
PostPosted: Fri Jan 11, 2013 9:05 am
Those points are excellent. Screw them in and you don't need to look at them from one end of the year to the next.
I used to keep a spare set of points in the car, but I gave that away a long time ago with the new electronic modules. I also picked up the high energy version. Its a different module and runs the low ohm (< 1.4 Ohm) coils like the GT40R or other high voltage coils.
http://www.simonbbc.com/ignition_module ... nce-module
PostPosted: Fri Jan 11, 2013 1:15 pm
I bought one of his dizzys a couple of years ago and havent had any issues.
Alec
PostPosted: Fri Jan 11, 2013 7:46 pm
check to see if the little cam in the dizzy is centered. So mark one lobe set the points gap give it a spin check re postion the lobe you first started with it should be as you set it.
Then check the other gaps on the other lobes. You will soon see which one is out
Too fix it you give it a sharp tap with a small hammer. In the direction you want to move
the cam. If the dizzy is 45d these can give problems if the small plastic cap that holds the cam in has popped up.
Dizzys and point setings are best done out of the car.
Kiwiinwgtn
PostPosted: Fri Jan 11, 2013 10:36 pm
The above is good advice.
Another thing to check is if the points are getting too hot, and the plastic is melting, which leads to the gap closing.
Users browsing this forum: Bing [Bot] and 75 guests
