It is currently Sat Jul 26, 2025 10:20 pm
PostPosted: Tue Jan 15, 2013 4:44 pm
Ok, help.... It has 7inch discs but has a 1275 a+ fitted....
What tells me its a cooper apart from the plate?
Ta guys.... [/u]
PostPosted: Tue Jan 15, 2013 4:53 pm
J hooks for the fresh air heater
Mesh grille for fresh air heater duct behind grille
100mph speedo
Trim around doors
Check the numbers yka2s1 etc.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Tue Jan 15, 2013 5:06 pm
Sliding windows
No hydro
Numbers stamped on the body
PostPosted: Tue Jan 15, 2013 5:36 pm
Where would I find number? Could someone give me a pm and call?
PostPosted: Tue Jan 15, 2013 5:38 pm
It's got a 64 wiper motor and that plate number, doors have been swapped out and rubber suspension
PostPosted: Tue Jan 15, 2013 6:23 pm
The car number on the plate , should match the number stamped into the firewall,below the plate , and the number on the radiator shroud if the car number is after about 2000 should be very close to that number . If however its a very late car the radiator shroud number should be around 500 below the car number .
Edit : Should have black vinyl covering on top and bottom dash rails,electric fuel pump, if its a 998 Cooper it should also a have nylon breather for fuel pump under left hand side passenger seat (or hole where it was)
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Jan 15, 2013 6:44 pm
patch over where the 850 gear sticker came throught. at the front of the tunnel.
Users browsing this forum: drmini in aust and 86 guests
