It is currently Wed Jul 30, 2025 6:37 am
 Post subject: Roof lining Bows
PostPosted: Sat Jan 19, 2013 7:26 am
Re-doing the roof lining in the Mini (1972) and want to check I have the bows in the correct position. (They are not the original ones from the car and have been in and out a few times).
I have 4 different types and they came out in the following order from front to rear:
1 “flatter” one that was at the front.
Then 3 the same.
Then 1 a little shorter.
And then the shortest at the rear.
Looks OK to me but can anyone confirm if this is correct?
PostPosted: Sat Jan 19, 2013 10:09 am
well i havent pulled out my roof lining yet , but my manual says they are fitted from front to rear and are colour coded , 1 red , 2 and 3 green , 4 blue and the 5th one is yellow. hope that helps.
cheers bill
PostPosted: Sat Jan 19, 2013 10:24 am
Hi Bill,
I will check the colours,
but
I have 6, not 5.
Could it be 2, 3 & 4 green, then it would line up with my lengths.
PostPosted: Sat Jan 19, 2013 10:39 am
i think the colours above are for pre 70's
what about this one it says for mini saloon range from front to rear, 1 red , 234 white , 5 blue , 6 yellow
Edit
These colour codes are from the blue leyland australia manual
Cheers bill
PostPosted: Sat Jan 19, 2013 11:04 am
Hi Bill,
Those numbers line up with mine, but not the colours.
From front to rear I had red, yellow, green, yellow, orange, no colour.
But mine may not be a set due to the car history.
The green one looks the same as the yellow ones.
Do any have an orange one?
Which manual do you have?
Dave
PostPosted: Sat Jan 19, 2013 11:18 am
These are the ones i have , the colour codes from above are from the top left dark blue one i will look through the others to see if they are different.
PostPosted: Sat Jan 19, 2013 11:26 am
I think those colours refer to the English cars.
It will be interesting to see what colour yours are.
But it looks like I need to get a proper set for mine.
PostPosted: Sat Jan 19, 2013 11:34 am
Those colours are out of the leyland australia manual , strangely i cant find a mention of the colours in the other 3 , the haynes restoration manual only gives fitting instructions.
Users browsing this forum: whitebuffalo and 117 guests
