It is currently Wed Aug 13, 2025 9:13 am
Post new topic Reply to topic  [ 114 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
PostPosted: Wed Jan 23, 2013 9:27 pm
NG wrote:
its 11/2" bigger then a balljoint nut joe..
I have a 1 5/16" 1/2" drive and a massive 2" 3/4" drive deep socket used for removing metro ball joints. Sure it's 1 1/2"?
I picked mine up at total tools, I think they only have it in a large driver though so you may need an adaptor
Ryan
Ryan
LS1275 - Hi Ho Silver
Moke 1981 - Mokee
Moke 1981 - Project
Moke 1978 - The Yellow One
PostPosted: Wed Jan 23, 2013 9:36 pm
Flywheel bolt is 1-1/2" (short socket is preferable for in the car jobs)
The balljoint retaining nut is also 1-1/2" but you want a deep socket for that one
The diff pinion nut is 1-1/2" also a deep socket
NG go into a Trade Tools shop if there is one near you. They will have both short and deep impact sockets, possibly in both 1/2 drive and 3/4 drive all sold separately. They are good tools and well priced, probably cheaper then anywhere else.
http://www.tradetools.com/stores
PostPosted: Thu Jan 24, 2013 7:07 am
thanks matt. ;) there is a trade tools in eagle farm.. not far from me at all.
ill zip up today & grab the short socket type as im doing it in the car.
PostPosted: Thu Jan 24, 2013 4:37 pm
1 1/2" socket was one of the first special socket I bought
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Jan 24, 2013 4:47 pm
well i forgot to mention mine is rover.. so metric lol.
30mil it is! doh! oh well.. I have a spare socket now :)
will pull this off tonight
PostPosted: Thu Jan 24, 2013 6:21 pm
doh! sorry man
I'm sure you could probably sell it to someone with an early mini if you don't want to keep it.
PostPosted: Thu Mar 14, 2013 8:18 am
well i'm still moving on this slowly, i basically have the last part i need.
sitting in the garage.
once this arrives, i can finally get it balanced & bolt it all back up & get a move on.
it's a verto alloy flywheel setup, 7075 grade alloy with a steel insert & it's very light around 2.32 kg.
the verto set up is very heavy as is, this should really work out nice.
it's been a long road but im nearly there.
i have to say with out 'ben92' i could have not go this far.. thanks for all your help on the phone mate. hehe!
Uploaded with ImageShack.us
PostPosted: Sat Apr 27, 2013 8:43 pm
what one should i use, i have a modified 2 core ebay rad as well..
im going with 6inch dual suction fans but im not sure what to use.
im thinking the longer one the fiat rad..the turbo boys run it tried & tested it works & they can just get there car to operation temps when giving it a bit.
with our hotter climate im thinking it would be good.
the other is a ebay 2core modded.
what do you think.
