It is currently Mon Jul 21, 2025 4:07 pm
 Post subject: Radius arm pivot pin.
PostPosted: Sat Jan 26, 2013 7:17 pm
Thanks drmini for helping me get logged in.
On the rear radius arm of a 1971 clubman, do the large washers go on the inside of the bracket and subframe or on the outside next the the nut... I think it's the inside but forgot to take a picture of that particular part
Thanks
PostPosted: Sat Jan 26, 2013 7:20 pm
I am assuming you mean the large thick washers with the eccentric groove cut into them? If you do, then they go on the inside against the radius arm with a rubber ring around the outer edge. Groove side inwards.
PostPosted: Sat Jan 26, 2013 7:21 pm
Yep that's what I mean, thought so but just checking..... Will get there eventually
Users browsing this forum: drmini in aust, timmy201 and 80 guests
