It is currently Fri Jul 18, 2025 1:50 pm
 Post subject: Engine size
PostPosted: Tue May 03, 2005 10:27 pm
This might sound like a silly question, but how do you tell what size a mini engine is? I cant find anything saying what size it is. :?:
go hard or go home
PostPosted: Tue May 03, 2005 10:31 pm
Check the engine number for a start
Apart from Cooper S's..,
if its 1st prefix number is 8 it's an 850, 9 is 997 or 998, 10 is 1098, 12 is 1275. 99 is a 998.
Or rather they were,.. when built. :lol: Lots of 998s seem to have had 1098 cranks fitted lately. Must be the weather.. :wink:
 Post subject: .
PostPosted: Tue May 03, 2005 10:55 pm
You *can* put 1100 pistons on a 1000 crank... They stick out the top of the bore, and give you MASSIVE compression, and they clear the head somehow, too... just some things you see around the traps. People just assume the engine number when ordering parts, and dont check the stroke measurements. Amatures. Oh well. At least they still go, and dont try to knock the head clean off the block.
PostPosted: Wed May 04, 2005 8:50 am
yea, my 99H8 prefix block is now an 1115cc :lol: :wink:
PostPosted: Wed May 04, 2005 9:38 am
how?
PostPosted: Wed May 04, 2005 9:46 am
see avatar..... :lol: I stroked it!
99H8 block = 998 motor (in theory)
Add a 1098 crank, bore it +.020", and you have an 1115cc 998 motor.... :lol: :wink:
1100 crank and a overbore, by lets see danidad's was .040 and came out at 1132 so I am guessing a 0.30 overbore. :wink:
Can you still get 0.030 thirty thou overbore 1100 pistons :?:
I had read somewhere they were not made anymore and you had to go to 40 thou ones :?:
Roads need more corners
Last edited by fuzzy-hair-man on Wed May 04, 2005 10:03 am, edited 1 time in total.
PostPosted: Wed May 04, 2005 9:47 am
Simultaneous posting and I was ten thou out, Bugger :oops:
PostPosted: Wed May 04, 2005 9:57 am
hhe... forgot about the boring... :)
damn... you;ve got 17 cc's on me.. ;)
PostPosted: Wed May 04, 2005 10:30 am
That Avatar Jam... .... :roll: :roll: :roll:
Lillee - 1969 Morris Mini K
PostPosted: Wed May 04, 2005 11:26 am
stroking a 998 is silly, they're bulletproof stock!
1100 cranks are weak.
PostPosted: Wed May 04, 2005 12:06 pm
The my 1100 is way more fun than my 998 lots more torque which is what I want.
You have a 1100 anyways says so in your signature :P
Do these really bust that often? I had heard that the 1100s from other BMC cars (non minis) had larger cranks how do these go?
does anyone know what engine numbers these were?
 Post subject: Re: Engine size
PostPosted: Wed May 04, 2005 12:13 pm
there's an EH in my street and the owner has cut up a HOLDEN badge and stuck it on saying OLD EH
PostPosted: Wed May 04, 2005 12:33 pm
it's weak for high revs..
dunno what engine numbas, theres no doubt 1100's pull much harder..
1100 cranks get nasty harmonics too..
Users browsing this forum: 1071 S and 107 guests
