It is currently Fri Jul 18, 2025 9:09 pm
 Post subject: Spotlight brackets
PostPosted: Mon Jan 28, 2013 3:50 pm
Can anyone advise how to fit spotlight brackets to a Round nose? These are the typical brackets available across the net.
I can't find any info on how the actually attach to he car.
PostPosted: Mon Jan 28, 2013 3:54 pm
i have a crossbar welded to my nudge bar on both my vans wit the spots mounted on it . works OK and the light are protected.
65 panel van Sprog
73 panel van Iggy
PostPosted: Mon Jan 28, 2013 4:51 pm
Usually some holes have to be drilled in the body somwhere for the brackets to mount too, for example, I had to drill four holes just under the grille behind the bumper.
PostPosted: Mon Jan 28, 2013 10:03 pm
I'm not sure about roundies, but with my clubby I just took off the grill, drilled two holes and made them out of some aluminium bar. They've worked fine for the last 2 years. Just make sure you use some big washers to prevent them from tearing the sheet metal if they get knocked.
