It is currently Sat Jul 19, 2025 9:41 am
 Post subject: few jobs on clubby doors
PostPosted: Wed Jan 30, 2013 11:32 am
Hey all,
It's time to start doing odd jobs on the mini that I've been putting off:
A while back the barrel came out of my passenger door lock (the outer part stayed in place), is this fixable or is it new lock time?
Also, the quarter window handle/catch came off, I have heard that I'll need to replace the window but it's a PITA of a job. Is the handle fixable? I use the winow so I'd like it to be operational(I've heard suggestions of just sealing it up... no thanks!)
How do you fit the outer door glass rubber? I bought one ages ago but just couldn't get it done...
Cheers!!!!
78 Leyland Mini - Prince
PostPosted: Wed Jan 30, 2013 11:41 am
Minisport SA had the little pin and spring that holds the quarter window catch inplace
You may need to drill out the old pin in the handle
Should be able to see the hole. Tiny drill needed and some patience
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jan 30, 2013 1:07 pm
Hi Michael,
cheers for that, I shall add it to my shopping list!
PostPosted: Wed Jan 30, 2013 2:08 pm
Never mind, just saw the clips that fix it to the chrome... i thought the tabs inside the door would bite on to it. :oops:
