It is currently Tue Jul 22, 2025 1:10 pm
 Post subject: Hydrolastic Pump
PostPosted: Sat Feb 02, 2013 2:02 pm
Has anyone had any experience with this item
NEW Hydragas,Hydrolastic MGF Metro 1100 Suspension Pump
Mini,1100,1300,Allegro,Maxi,Ambassador,Princess,1800
Item condition: Brand New
Item number: 181070940515
GBP 51.25
Approximately AU $77.90 Buy It NowBuy It NowBuy It Now
Postage: GBP 27.00(approx. AU $41.04) - Royal Mail International Signed-forSee more services See postage discounts
Start of LayerEnd of Layer | See all postage details
Item location: Dursley, Gloucestershire, United Kingdom
Posts to: Worldwide
Import charges: To be provided at checkoutThis amount includes applicable customs duties, taxes, brokerage and other fees. This amount is subject to change until you make payment. For additional information, see the Global Shipping Program terms and conditions- opens in a new window or tab.
Delivery: Varies for items posted from an international location
Seller posts within 10 days after receiving cleared payment - opens in a new window or tab.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Sat Feb 02, 2013 2:11 pm
Hey John,
I just literally enquired about it yesterday and will order it at the end of this month. It comes with a Low Loss Valve option which is extra and for a further 12GBP you can buy a vacuum adapter for the Low Loss Valve which essentially will make it work with any vacuum including hand held ones of the brake bleeder type.
Apparently with all of this for about $200 posted, it can do what those factory pumps can. Opening up a bypass valve, applying vacuum to suck out the air, then close valve, and pump in new fluid.
If you buy it first let me know otherwise I will give you the full review in Feb.
PostPosted: Sat Feb 02, 2013 2:19 pm
It is a grease gun. You could buy one here and get a Schrader chuck fitted to it.
The big problem with the grease gun is they are slow.
You could do what Drmini and myself both did and make a hydro pump from a master cylinder.
There is no need for a vacuum pump. You just fill it up and let it down a few times to purge the air out.
PostPosted: Sat Feb 02, 2013 2:31 pm
I've thought of making my own for 10 years, and by the time you collect all the bits and pieces and weld (don't have a welder) I'd rather just pay $70....
PostPosted: Sat Feb 02, 2013 4:30 pm
I bought one and they work a treat. Thought it was completely poxy to start with until I put a new valve in the end of the hydro line and it held pressure. Yes a bit slow, but how many times do you need to be messing around with your hydro. The gauge stopped working pretty quick but think it may have been me that buggered it with the faulty valve.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Feb 02, 2013 5:21 pm
Give Ash some flowers Nick .
Chong, you can make your own without welding. I put together my grease gun hydro pump with fittings from Pirtek, a valve from a US website and a pressure gauge off of eBay. It all just screwed together. Having said that though the valve from the US was about $50-60 so the $70 value of this one is very, very good.
PostPosted: Sat Feb 02, 2013 5:28 pm
I have one. As mentioned by Babes it works really well. Yes its a little slow but who cares, I might play with my height 1 or 2 times a year.
To let down the system I just pushed a bike pump valve end onto some hose and use that to drain the fluid out. Then use the hand pump to fill it up
PostPosted: Sat Feb 02, 2013 5:34 pm
I still have the one I created a few years ago. Its made from a grease pump and some fittings. It doesn't make a mess and is very fast, I think about 20 pumps and its done. The tank holds enough for both sides and more. The lines drain back to the tank to bleed the air out of the system.
Have you still got the one you made up SGC?
PostPosted: Sat Feb 02, 2013 6:01 pm
I made one as per Mick's design, works a treat, and looks the goods.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Sat Feb 02, 2013 6:39 pm
Thats pro
PostPosted: Sat Feb 02, 2013 6:48 pm
Mick's one looks much better than this one...
But how about this one...
Or the porn version...
PostPosted: Sat Feb 02, 2013 6:55 pm
lol that Grease pump one looks awesome! But I think it would cost more than $70??
Glad to know it works well. All I want is the odd occasional pump up or flush. The fact that it's $70 or $200 for the full monty with vacuum is a nice thought.
PostPosted: Sat Feb 02, 2013 7:07 pm
From memory I think all up it was about 120 or 130 to build.
The original hydro machines are awesome, especially with vacuum if it works, but they get pretty expensive if you're after one. You can omit the need for vacuum by pumping up and releasing three of four times. The air gathers at the high points and blows out to the tank as you release it. Without an original pump with vacuum, all other types of pumps need to cycle the hydro up and down a few times to flush them out.
I used the grease pump because the grease gun based units need to be refilled mid pump up at least once which makes things pretty messy and introduces the chance of air getting into the fill.
Here's the build link:
http://www.ausmini.com/forums/viewtopic ... hydro+pump
PostPosted: Sun Feb 03, 2013 8:29 pm
:!: Exterminate :!: Exterminate :!:
PostPosted: Mon Feb 04, 2013 11:15 am
This space for rent
Absolutely! Still works well, although it doesn't get much use these days :)
Users browsing this forum: timmy201 and 83 guests
