It is currently Sat Jul 26, 2025 12:40 am
 Post subject: Rover alternator belt
PostPosted: Mon Feb 04, 2013 4:49 pm
It is the one that goes around the alternator and the ac unit . I have been told it is 11A0590 who or where can I get one . Cheers
PostPosted: Mon Feb 04, 2013 4:50 pm
What year car?
PostPosted: Mon Feb 04, 2013 5:01 pm
You might just be able to front up to a good local carparts shop and get one. Sometimes they can cross match from the belt, or even measure up your old one with a u-beaut gauge that they should have.
'68 Deluxe w/Metro engine
PostPosted: Mon Feb 04, 2013 5:12 pm
Off the top of my head i think the 590 should be the actual length of the belt so any auto shop should be able to get one.
That is if the part number you have is right.
Really need year model and belt type.
Ie v belt or rib
Lot of Rover owers on here should be able to help further.
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Mon Feb 04, 2013 5:40 pm
11A is the profile size for v belts. This is the correct size for old minis, not sure about rovers, but probably the same.
0590 is the length which would be moderately shorter than a standard fan belt on an old mini.
Any auto shop should be able to help you out unless they are out of stock. Providing that is the correct size.
PostPosted: Mon Feb 04, 2013 6:11 pm
My 1993 rover had a thing belt like the alternator belt hooked up for the A/C compressor and now my 1997 Rover has a thin flat belt in it's place. The fat belt does not have any markings on it though.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Mon Feb 04, 2013 6:52 pm
The serpentine belt is a 5PK1000.
Users browsing this forum: Bing [Bot] and 105 guests
