It is currently Tue Aug 05, 2025 11:31 am
what to do with automatic gearboxes
Poll ended at Sun Feb 17, 2013 11:04 am
keep and store 46%  46%  [ 12 ]
use 35%  35%  [ 9 ]
dump 19%  19%  [ 5 ]
Total votes : 26
 Post subject: automatic gearbox
PostPosted: Thu Feb 07, 2013 11:04 am
What are the mini automatic gearboxes like?
Have picked up two 1000 engines with auto boxes fitted. No idea what they are like. Should I keep them, sell them, or use them?
frank
Roundy Sedan project with/for daughter
PostPosted: Thu Feb 07, 2013 11:44 am
well if your like my partner who can only drive an auto they are a must! lol
PostPosted: Thu Feb 07, 2013 12:36 pm
If you don't need/want outright speed the Autos are fine. Just look after them religiously or they will pack up.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Feb 07, 2013 2:41 pm
I hope you realise the auto motors will not work on a manual box unless you modify the oilways.
See my sticky at top of the mods forum.
BTW the heads on the 1100 automatics are the 12G295 (same as on a 998 Cooper)- are much sought after by Mini owners.
PostPosted: Thu Feb 07, 2013 7:47 pm
Thanks for that, I had no idea, I've read that other thread now. Wonder if I will remember it when I need to.
Is there any easy/obvious way of determining if they are any good, or stuffed?
Looks like the vote is to keep them, now I have to make some space somewhere. Anyone want a 1968 Toyota Crown MS53 series 1 wagon tailgate.
PostPosted: Thu Feb 07, 2013 8:01 pm
The weakest part in them is the facings on the top/reverse and forward clutch plates. They are pretty much just paper. Late model ones are kevlar, more durable.
Parking them for long with dirty acidic oil in buggers up the clutch facings, and can also etch the tracks of the needle roller bearings it is full of.
If you are keeping them for future use I would drain all the oil out then refill to the full mark with some fresh cheapo 20W/50.
PostPosted: Thu Feb 07, 2013 8:09 pm
If the Crown tailgaye is in good nick it should find a home on Toymods. I actually know someone restoring an MS53.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Thu Feb 07, 2013 8:26 pm
my matic sat idle with a sump full of oil for nigh on 14 years plus - touch wood, 18+ months later after starting it backup, no probs as yet and have driven it almost every day since
I say sell one to me as a spare just in case :D
PostPosted: Thu Feb 07, 2013 8:33 pm
Minimatic would have been a nicer drive if they had put the 1098 in it. Much more torque than the auto 998 has.
I had a very good 1275 autobox sitting here, it was in my way, I had no room and it had to go, I ended up selling it for $50 complete (no motor). :cry:
PostPosted: Thu Feb 07, 2013 8:41 pm
I have convinced the missus that if any cheap auto gearboxes and or engines are up for sale, I should get it as a back up just in case
I'd have to move a few drum kits to store it, but I'd find the room :D
PostPosted: Thu Feb 07, 2013 9:17 pm
Steve, PM sent.
PostPosted: Fri Feb 08, 2013 4:57 pm
send them all to me & i`ll fit big phat 6-speed sequential motorbike gear-kits into them
PostPosted: Fri Feb 08, 2013 6:59 pm
If anyone wants them, we will exchange them for parts we need or $$.
Located in Ferndale, Perth, WA and probably not worth freighting anywhere.
PostPosted: Fri Feb 08, 2013 7:32 pm
What parts are you after Frank?
PostPosted: Sun Feb 10, 2013 9:10 am
So far this is what I know we don't have:
Front Bumper - have what I guess is a clubman one, doesn't fit, different mountign style.
Tail lights - have a set of van ones instead, will swap for roundie ones
Front and rear carpets -
door cards -
firewall cladding
firewall hole covers - 1 large front, 1 small front.
rear seat back hole cover
interior linings - missing all of these
trim for side boxes
ashtrays for side boxes
seatbelts
probably heaps more, this is just what I have noticed, and we haven't even started putting it back together yet.
Frank
Users browsing this forum: Bing [Bot] and 84 guests
