It is currently Thu Aug 14, 2025 5:57 pm
 Post subject: heating
PostPosted: Tue Feb 12, 2013 3:28 pm
okay fellas I wanna know what temperature your mini should run at in this heat in the thirties ? ok in farenheit ? my brothers vcar is running on 200 bit hotter if goin up a hill. where my brothers clubman stays on normal
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Tue Feb 12, 2013 3:40 pm
The first thing I would say is to only treat the gauge as a guide. Many variables determine where the needle sits for "normal" temperature.
To help get familiar with my car, I stuck the wife's digital kitchen thermometer in the radiator and noted needle position for given temps. This only worked up to a point, as the system started spitting before the thermo fan kicked in. Nonetheless, a useful exercise for me.
So in my case, the temp gauge is reading too high, so a mate is going to help me install a resistor in the circuit to drop the needle down to a more realistic level.
Hope this helps.
'68 Deluxe w/Metro engine
PostPosted: Tue Feb 12, 2013 6:02 pm
he has a mechanical guage fitted
1970 mini k
1975 leyland
PostPosted: Tue Feb 12, 2013 6:38 pm
Degrees Fahrenheit - Degrees Celsius . . . _?_ minus 32, multiply by 5 divide by 9 = ?
200
-32
x5
/9
93.333333334
PostPosted: Tue Feb 12, 2013 6:41 pm
so 200 is no problem? 210 215 up a hill no worries?
1970 mini k
1975 leyland
PostPosted: Tue Feb 12, 2013 7:01 pm
212 degrees fahrenheit is 100 degrees celsius, so yeah is ok but youll find car runs better/happier around the 200 mark
PostPosted: Tue Feb 12, 2013 9:44 pm
ok thanks ballistic my brother was saying his car is over heating because it sit around the 200 mark a lil bit higher at times this should put him to rest I think lol., thanks for all your help
1970 mini k
1975 leyland
Users browsing this forum: justminis, Majestic-12 [Bot] and 236 guests
