Hay Brenton you will find the code on the barrel for the door locks
Just pull the retaining spring off the end of the lock…… then pull the pin out…..or let it drop out……..best to do this over gravel so you will never find it again…
Then pull the inner barrel out……you might have to clean the crud off to see the numbers.......but a good time to really clean the lock.
should be three numbers........well all four inner barrels i have in front of me only have three numbers stamped on them.
The locksmith I use has the standard English codes on his data base so have never had problems getting keys cut.
I think the rear boot lock is the same…….number on the inner barrel….can’t remember seeing it the last time I had one apart……….as the key I had was close and just needed to be filed for one of the wafers to get it working.
I’ll dig out some rear boot locks tomorrow and have a look…….if I can remember where I put them in the shed......
Cheers Neil………..
