Timbo wrote:
Yes the 998 and 1100 block are the same, as are the conrods. The crank and pistons differ. If you're fitting a 295 head to a standard 1100 (or a 998) with flat or dished pistons you need to plane a substantial amount off it to get the compression ratio right. The problem is that you need to do the calculations for the engine you're fitting it to and modify the head to suit. If you later decided to convert your 1100 to a 998, you might find that the compression ratio is no longer correct.
If it's a 1098 with flat tops + 295 head, the C/R will be about 8.9:1 (same as Mk2A Sprite was). Of course if overbored +.080 or more, the C/R will be higher.
If it's a 998 with flat tops it'll be less, if a 998 still with dished pistons it'll be a LOT less (under 8.0:1).
Most Mini engine tuners in Sydney (well, the 3 I talk to) say don't shave a smallbore head more than about .070" tops. The deck gets too thin, which can give gasket sealing problems.
As you say, some calcs need doing.
@XC9000,
a 202 can be made to outperform a 295 but it takes lots of time and $$$. I have done a few roady ones in the past. GR still does them for race heads, but take your $,$$$ with you.
[edit] here's a couple of shots of the last 202 head I did, before chambers got polished.
Chambers are pretty big in 2nd pic because it was going on a Sprite 1098 bored to 1220 with Imp flat top pistons.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
