It is currently Wed Aug 13, 2025 2:30 pm
 Post subject: is this normal ?
PostPosted: Sat Feb 23, 2013 5:23 pm
Die Die Die!!
i was about to wire wheel the top arms i pulled off the moke when i noticed that oen had a metal square welded onto it..
is this normal ?
PostPosted: Sat Feb 23, 2013 7:28 pm
I think mokes have them
PostPosted: Sat Feb 23, 2013 7:36 pm
You are gunna be in deep, deep trouble if you start wire wheeling there :!: :lol:
PostPosted: Sat Feb 23, 2013 7:52 pm
Die Die Die!!
and why is that ?
PostPosted: Sat Feb 23, 2013 8:25 pm
_666_ wrote:
and why is that ?
It looks like it's inside a house because of the tiled floor.
PostPosted: Sun Feb 24, 2013 9:36 am
Yep...don't wire wheel in the kitchen! :lol: BUT do wear lots of protection, and not just for the eyes...those little wires can fly off at a great rate of knots.
PostPosted: Sun Feb 24, 2013 11:06 am
Yes, late mokes have those square blocks welded on. Many fall off as the small welds crack. I don't run them on my moke as I set the ride height lower than standard.
M
PostPosted: Sun Feb 24, 2013 3:23 pm
M
Same.
And my bump stops are modified also.
I have about 10mm (maybe less... actually definitely less) of travel between my bump stop and the top arm.
Users browsing this forum: No registered users and 178 guests
