It is currently Mon Jul 21, 2025 3:22 pm
 Post subject: Van tank sender screws.
PostPosted: Mon Mar 04, 2013 7:37 am
Hi,
Does anyone know what the thread size is for the sender screws on a van tank?
Some clever cloggs lost our screws.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Mar 04, 2013 8:20 pm
I think I have some spare - will look tomorrow. Never know what might leap out of the shed in the dark :)
Cheers, Ian
PostPosted: Mon Mar 04, 2013 9:33 pm
I could be wrong but they look just like the screws that screw down the float bowl on an SU.
I pulled the fuel tank out of the moke the other day
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Mar 05, 2013 10:51 am
Hi,
They are not the same as the SU float bowl screws. Or the roundie tail lights.
Ian, if you have some lying around, that would be great.
Also we are looking for a few of the plastic posts that the large screws go through to secure the tank to the bodyshell.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Mar 05, 2013 11:49 am
Online
In case it helps the screw part number is 53K165.
http://www.minisport.com.au/prod1946.htm
http://minirichs.com/21.html
The nylon posts are 21A304.
http://www.classicmotoring.net.au/cmos/ ... ts_id=1013
I know you are looking for donations but thought the above might assist in the search.
PostPosted: Tue Mar 05, 2013 9:32 pm
Hi Brett, Yes, I have 6 screws and the little brass washers.
And probably the nylon plugs as well. They come from my Traveller tank so I'm assuming they're the same. The look like the float bowl items but are a bit longer with posidrive heads.
I suppose I could swap them for something useful - like a spare Trav shell :)
Send me a PM with your address (Again :). What's the required time scale??
Cheers, Ian
