It is currently Sat Aug 02, 2025 10:00 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Heads
PostPosted: Wed Mar 06, 2013 7:02 pm
Location: MinisintheGong [Somewhere on the South Coast]
Yes you can get more torque (on a smallbore) from a radically modded 202 or 295 than a 940. Because, the ports are smaller and gas speeds are higher. Works great for smallbore motors.
But, this costs you time & $$$ for the porting and new parts (big valves, etc etc).
OTOH, a stock 940 (1100S) head with an hour or 2 spent deburring the insides will give better HP than a stock 295 at minimal cost.
As others have said I agree with notching the top of the block, if you are after HP. You won't get big HP with stock cams.
Torque with a 940 head on a smallbore may be less at lower speeds, however my 1220 motor was doing low 16s at Castlereagh dragway back in the late `60s. And the head was an 1100S with stock valves, double springs and a bit of basic porting.
Mind you the 544 cam and twin HS4s helped...
Sorry I won't be coming down next weekend, as I'm off to Brissy for Matt Read's 50th knees-up. :P
Thanks Kev. i knew you were going up to Matt's and overlooked the overlapping dates. i hope its a great night for Matt, after what he's been through he deserves a break and a good celebration. My bro & I had planned attending but he cant make it, I have the MITG run this weekend, one of our best:!: Its a must:!: (for me in any case I think you'd understand)
Thanks for the help with the head. It was Matt that told me that including X2 valve springs was not the be-all and end-all. I have only one spare 12G940 on an 1100s engine allocated for an off-road car I will build later so it makes sense to use the 'Waggot' head on my registered 998 car. Plus I'd prefer to run an upgraded cam and i dont want to plane the block etc to a reliable road car.
But what about the valve guides? Can i knock the valves out that are frozen in the guides :?: Can you please tell me are they easy to get:?: :cry:
Thanks in anticipation
Wayne
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Wed Mar 06, 2013 8:22 pm
Punch the valves out of the guides. Then you would want new guides, or K-liners in the old ones.
New iron guides are cheap, less than $50/set.
Bronze guides are 50% dearer but they can give problems- they all need reaming after fitting, & the current manganese bronze ones tend to close down in diameter after a few heat cycles. This can grab a valve...
K-liners are best, around $160 to get a set fitted.
PostPosted: Fri Mar 08, 2013 10:39 pm
Thanks for the help Doc, very grateful...
Have a good'n this weekend in Bne. i hope it all works well for Matt.
Wayne :)
