It is currently Thu Jul 24, 2025 12:00 pm
PostPosted: Sun Mar 03, 2013 2:37 pm
Has anyone ever attempted to replace the lock cylinders (barrels) on the drivers door, boot handle and ignition of a Mk2 (winding window) mini?
I'm thinking of buying the lock barrel set online and doing it myself but have never attempted it before and have no idea how to remove and install the barrels;
http://www.7ent.com/products/lock-barre ... h9635.html
Alternatively, does anyone know where in Adelaide I could get it done without costing an arm and a leg?
Any assistance or advice would be most welcome.
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Wed Mar 06, 2013 6:37 am
Just noticed these locks are for sliding window cars-guess it's time to visit the locksmith!!
PostPosted: Wed Mar 06, 2013 9:35 am
I bought one of these in but had trouble getting my spare Mk2S handle unlocked first (finally gave it away). So I still have the UK Mk1 tumbler barrel and key somewhere.
I reckon the barrels would be the same, even though the 2 door handles are different.
I will ask John Smidt today. :wink:
PostPosted: Wed Mar 06, 2013 9:51 am
Thanks Doc, It would be good to find out if there is a difference between the sliding window and winding window doorlock barrels.
Other websites seem to suggest the barrels are different for the two types of door so I'm a bit wary of getting stuck with ones that don't fit.
The 3 barrel set I've mentioned does seem an attractive proposition as you could potentially have new and matched ignition, door and boot keys for the car.
Dave
PostPosted: Wed Mar 06, 2013 10:13 am
John is not sure if the same or not. If I can find my new one I will compare it to a windup door one there on Friday.
PostPosted: Wed Mar 06, 2013 12:19 pm
I assume the roundies also used an FS key
I have jjust recently pulled a bunch of clubman locks apart and rekeyed some boot handles to match my door locks.
Its not hard.
Just dismantle the lock you have and pull the wafers out and line them up in order they came out (dont mix them up)
Then dismantle a boot lock and find enough wafers from the dismantled locks the same size as those removed and insert in bootlock and reassemble and your door key will fit,
There are only 3 sized wafers in all FS locks *basicaly small medium and large).
Its really really simple.
PostPosted: Wed Mar 06, 2013 3:33 pm
Just asked at Minisport SA and they reckoned the UK sliding door and Aussie windup door key barrels are different. If you take the old door, ignition and boot locks in to them, they repin your old barrels and key them alike for less than $100. I may do this as I don't have any spare locks to play with
PostPosted: Wed Mar 06, 2013 4:21 pm
$100 thats a bit of a rip.
I assume they would be the same as a clubman (ie they all use an FSXXX key). Have a go at doing it yourself, its not hard.
PostPosted: Wed Mar 06, 2013 7:13 pm
Thanks Bubbacluby, I don't have anything to lose as they aren't working now so I'll give it a go myself first.
Cheers Dave
PostPosted: Wed Mar 06, 2013 8:52 pm
The Mini King
As I said I thought they were different But I was not sure ( old age0 However
Ihave checked And they are different
I can make You The key barrel for the Aust door handle If required
PostPosted: Wed Mar 06, 2013 9:08 pm
Thanks for the offer John but I'm going to attempt to fix them myself as suggested by Bubbacluby
I'll let everyone know when (if) I am successful
Dave
PostPosted: Wed Mar 06, 2013 9:47 pm
I picked up a set of lock barrels for my car some time ago. They work fine after the locksmith put them in for me.
A bit rough first up until the key loses its sharp edges, but a good fix all up.
PostPosted: Thu Mar 07, 2013 6:36 am
Mick-were they new ones from somewhere or old ones that were refurbished?
If they were new, do you remember where you got them?
Users browsing this forum: Goldbrocade_62 and 91 guests
