It is currently Wed Jul 30, 2025 12:00 am
PostPosted: Thu Mar 07, 2013 4:47 pm
As in the title, is this a big issue? The fuel line runs behind the LCB. I've bent the fuel line to run as far away from the downpipes from the manifold but it is closer than the standard exhaust manifold.
I don't really want the complication of an electric fuel pump if the mechanical one will be fine otherwise. It's standard tune (ATM) 1275.
TIA,
Simon.
PostPosted: Thu Mar 07, 2013 4:51 pm
The fuel going through the hose keeps it cool, but if you're worried about it put some heat resistant non-abrasive hose covering mesh over it.
 Post subject: Fuel and exhausts!
PostPosted: Thu Mar 07, 2013 8:02 pm
Get rid of the Mechanical pump and fit Electric. More sensible thing to do.
"Let us remove your "SHORTS"
 Post subject: Re: Fuel and exhausts!
PostPosted: Thu Mar 07, 2013 8:14 pm
Most Australian Minis got mechanical pumps to comply with Australian content rules. But the high performance Minis (Cooper, S and GT) all got electric... probably because they work better. :wink:
PostPosted: Thu Mar 07, 2013 8:16 pm
Why? :?
Surly a mechanical one is more reliable
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Thu Mar 07, 2013 8:24 pm
Why? :?
Well they have much the same valves as an electric one. But when the diaphragm gets a hole, they can leak fuel into your sump... :shock:
And aren't they a right PITA to get at with a decent exhaust system on.
PostPosted: Fri Mar 08, 2013 5:21 am
Why? :?
That's not been my experience. I've replaced a couple leaking mechanical, and one broken mechanical, but the only time I've ever had a problem with an electric was an original SU that was left to dry our for a couple of years. Started to leak around the top flange - however it was close to 50 years old....
PostPosted: Fri Mar 08, 2013 10:23 am
PDJ wrote:
Why? :?
If you plan on making any decent HP, a mechanical one just won't keep up in terms of output and pressure.
Lillee - 1969 Morris Mini K
Users browsing this forum: No registered users and 130 guests
