It is currently Tue Jul 29, 2025 3:03 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Post subject: That harness!
PostPosted: Fri Mar 08, 2013 6:20 am
That harness has the needed components but by the time you chop it up to adapt it to a Mini there will be nothing of it left. The male plug that they give you to plug into the existing Headlight Bulb plug is way too big to feed through the hole to get it to the headlight in any Mini. And if you use it as it is with it's full excessive length of cables you are more than likely going to be in the same boat with the Voltage drops you will end up with besides bundles of unnecessary cables being an eye sore under the bonnet. Those kits are designed for cars with Dual headlights like the Toyota Land Cruises 80 series. A bit bigger than a Mini. Much easier and neater to do it like I explained in the "How to" section a few years ago. Very simple if you are handy with a pair of side cutters some tape and a soldering Iron. Why complicate things?
"Let us remove your "SHORTS"
Users browsing this forum: fuzzy-hair-man and 108 guests
