It is currently Thu Jul 31, 2025 5:16 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Mar 11, 2013 3:04 pm
It appears that Minispares are now advertising their timing belt as a DAYCO one. And wobbles just bought 2 there.
So maybe we can now get decent ones AGAIN without searching the world.
http://www.minispares.com/product/Class ... 0belt.aspx
PostPosted: Mon Mar 11, 2013 3:58 pm
Has anyone tried PIES?
http://www.piesau.com.au/
These guys do nothing but power transmission. The MULCO website allows you to design your own solution and pick the best belt too.
PostPosted: Tue Mar 19, 2013 5:55 am
Does anyone have experience with the Mini Spares belt drive kit? It's a lot less money than the one that jb007 supplied a link to.
I note that this cheaper one doesn't have an idler; maybe important only on a race engine?
http://www.minispares.com/product/Class ... 0to%20shop
'68 Deluxe w/Metro engine
PostPosted: Tue Mar 19, 2013 7:39 am
Most of the Mini (Triger etc) belt drive kits have no idler. The belts fit TIGHT. Idler is not needed unless the belt is LOOSE (= chinese made, or block has been line bored since manufacture).
I have the earlier design belt drives on both my 1360 and 1412 motors and many race cars run them too. Mine are tight with both a Dayco belt and a MiniMania (Gates made) kevlar one. But I tried a Chinese belt and it was loose.
The Minispares kit pictured has dowel adjustment, mine just uses an offset cam key.
IMO the only disadvantage of all these belt kits now is they cost big $$$. OK on a racer but hard to justify for a road motor.
PostPosted: Tue Mar 19, 2013 7:38 pm
Thanks Doc. Good advice.
With the good AUD at the moment, hopefully it doesn't work out too badly.
PostPosted: Thu Mar 21, 2013 2:56 pm
Just wondering if it is possibly not worth the time or money on an otherwise standard roadgoing engine....
It seems like a real good idea to ditch the chain - quieter? less power loss driving a belt? more accurate cam timing?
Any opinons?
Thanks.
PostPosted: Thu Mar 21, 2013 3:19 pm
No quieter really as long as chain isn't worn out.
Might be worth a HP or 2 on a racer, I don't know.
I would use duplex sprockets and a Jwis duplex chain these days on road cars. Just advance the cam 2° to allow for future chain stretch.
You can get adjustable kits for more $$$ but I prefer std sprockets & an offset cam key.
Also remember on a road car you would need to fit a new belt @ 40,000 miles or sooner. To be sure, to be sure...
Duplex chain is more durable.
