It is currently Tue Aug 19, 2025 10:42 pm
 Post subject: 1100 S harmonic balancer
PostPosted: Wed Mar 13, 2013 4:25 pm
Is it safe to use a small bore harmonic balancer on an 1100S engine :?:
The engine will be either 0.40 or 0.60 thou over bore and crank is large journal 0.10 or 0.20 thou over on the journals and large journal rods.
Or should I get a cooper S balancer?
PostPosted: Wed Mar 13, 2013 5:39 pm
its the same part,
same part number too
PostPosted: Wed Mar 13, 2013 6:24 pm
Just make sure the rubber bonding is OK if it's s/h. Run a razor blade around the back to clean it off flush, if rubber isn't cracked then it's a good 'un. 8)
Users browsing this forum: No registered users and 123 guests
