It is currently Sat Aug 02, 2025 12:55 pm
 Post subject: What are these flares?
PostPosted: Thu Mar 14, 2013 10:09 am
Hey Guys,
Does any one know which flares these are?
And do they require a backing plate to be welded/riveted onto the panel or are they screwed/bolted on with a rubber behind them?
Also would these fit on a clubby?
http://www.minisport.com.au/prod497.htm
Thanks
1975 Hairy Lime/White Clubby
PostPosted: Thu Mar 14, 2013 10:36 am
Innocenti flares plastic screw in . Low cost easily replaced if cracked or damaged here's my effort with a chrome strip. Wheels are 10x6" ... Disc brakes & stepped drums. Still legal. stick some rubber behind then to protect your paint.
PostPosted: Thu Mar 14, 2013 12:46 pm
Thanks Fiji.
Yours look great... what did you use for the rubber backing? is it just flat rubber you cut from a sheet? or is it some type of moulding you can buy?
Thanks
PostPosted: Thu Mar 14, 2013 1:16 pm
It's a "u" shaped rubber backing I bought from minisport uk. But check out clark rubber should find something similar
PostPosted: Thu Mar 14, 2013 1:21 pm
Hey mate,
I bought this rubber from minisport UK, not sure if minisport SA stock it (haven't looked to be honest)
If you don't get screws with it, take it to a fastners place so they can find one with a reasonable size head to it.
This is them on mine:
1978 Leyland Clubman
PostPosted: Thu Mar 14, 2013 2:47 pm
tomtom wrote:
Hey mate,
Don't use the black steel screws that come with them, they rust, and it runs down the flares, which looks crap.
Go to a Boat shop eg Bias Boating Warehouse or Whitworths, they have S/S ones the same size. I just smear a bit of grease on and screw them in.
PostPosted: Thu Mar 14, 2013 2:55 pm
I've used these flares on early and late and when fitted with a bead to cover any mismatches look okay.
I fitted some in the ninties and made a bead out of vinyl wrapped around wire.
Image[/list]
Cheers Rob
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Thu Mar 14, 2013 3:22 pm
Fiji wrote:
There's some serious positive camber there mate! Time to get some adjustable suspension arms 8)
tomtom wrote:
Hey mate,
Ah yes, forgot that as well, I did get S/S ones.
PostPosted: Thu Mar 14, 2013 4:12 pm
Lillee wrote:
Yeh mate but that's the look I'm going for 8)
PostPosted: Thu Mar 14, 2013 6:39 pm
They are Mini Sprite flairs - a factory option from (I think) the 80s .... or replicas there-of.
What you see is what you get - they just bolt/screw on to the body.
They can be painted in body colour as mine are.
However, think carefully before going down that path. You will end up with a row of holes drilled into the body should you ever change your mind... B%^$&er!
Cheers, Ian
 Post subject: .
PostPosted: Thu Mar 14, 2013 6:46 pm
Location: MinisintheGong [Somewhere on the South Coast]
Dont go there:!: why not use the Innocenti or standard flares :?:
At least that way you are playing to a wider market if you sell the car.
I MUCH prefer the flares that you can fit the plastic side chrome strips to for a finer aesthetic presentation.
IMO. Sorry if I offend [old bloke thoughts] :x
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
 Post subject: Re: .
PostPosted: Thu Mar 14, 2013 7:39 pm
It's easy to get the chrome strip on the plastics they look better than most once they're done .
 Post subject: Re: .
PostPosted: Fri Mar 15, 2013 9:32 pm
if you are talking the standard factory type - agreed :P
PostPosted: Fri Mar 15, 2013 9:36 pm
I used the plastic Innocenti/Mini std flares, but I tossed away that silly bit of ill-fitting plastic strip that goes between them.
I used a bit of narrow black pinchweld instead. It stays on better and doesn't shrink with age like the strip does.
