It is currently Fri Aug 22, 2025 4:35 am
PostPosted: Fri Mar 15, 2013 9:23 pm
Hi, had a call from a guy who wants to sell me an alloy 5 port head. Trouble is he lives far away and i wouldnt be able to inspect it in person before buying it.
Dont know what make the head is. He said it was from Minisport
All i know is the head was fitted to a 1380 race engine run on av-gas.
He tells me one of the seats has come out and all i would need to do is get it put back in and away i go.
Because it has come out already is this going to be a re-occurring problem?
Looking for anyone who can shed any more light on this subject for me?
also any other problems to look out for with 5 port alloy heads
Thanks,
Claeten
- '74 Clubman Ute project
PostPosted: Sat Mar 16, 2013 10:51 am
need to see the head really
may have got hot?
PostPosted: Sat Mar 16, 2013 10:54 am
Most of the 5 and 7 port alloy heads are made by Pierce Castings in the US regardless of who is selling.
Poorly fitted seats are common. Not hard to rectify.
You'd really need to see how much damage the seat did to the valve & head
PostPosted: Sat Mar 16, 2013 5:54 pm
are they the ones that have the valve spring seat problems?
how do you rectify it mike?
PostPosted: Sat Mar 16, 2013 7:17 pm
You just need to remove the inserts and shrink fit them properly.
I'm considering going for bigger valves while I'm at it.
PostPosted: Sat Mar 16, 2013 7:25 pm
I would be careful - and ask for some decent photos of the outcome first.
I bought an 1275GT motor that had had seats fitted - and one had fallen out. The consequences for the relevant piston and combustion chamber were not pretty.... The block was fine with a new piston - but the head was passed on as not worth the bother....
Valve seats are a LOT harder than alloy.....
Cheers, Ian
PostPosted: Sat Mar 16, 2013 9:17 pm
it would always make a good ornament for the cabinet i suppose
PostPosted: Sat Mar 16, 2013 9:50 pm
make sure they're stuck in good - this is what happened when my S head dropped a seat...
more than just a replacement piston
Users browsing this forum: Bing [Bot] and 240 guests
