It is currently Sun Jul 27, 2025 8:11 pm
PostPosted: Wed Mar 20, 2013 9:50 pm
so they seem to keep stopping halfway i can't work out why.
i have tried to tighten the arms to the body but nothing.
I have to reach out with my hand give them a small push and they keep going again.
the motor seems to be working but not sure what is going on.
help!
:lol:
PostPosted: Wed Mar 20, 2013 9:58 pm
The gears may be worn, a possible fix might be to pull the cable out, rotate the wheels a bit and put cable back in. The objective is to get the worn teeth to an angle where they arent used when the wipers would be moving.
PostPosted: Wed Mar 20, 2013 10:03 pm
Would the contact plate in the motor be worn out in that spot? or do you mean the motor keeps working and just the wipers stop?
PostPosted: Wed Mar 20, 2013 10:04 pm
mine did the same, but it was because i hadn't cut the new wiper blades short enough and they were JUST hitting the windscreen rubber :P
PostPosted: Wed Mar 20, 2013 10:09 pm
yes the motor still keeps working i have to give it a helping hand to keep it going.
so you think a worn contact plate?
PostPosted: Wed Mar 20, 2013 10:26 pm
no,,, if the motor is still going & the wiper arms are not,,, then the contact plate is good still
if the contact plate was no-good then the wiper motor would stop at the bad section
sounds to me like you have worn wheels inside the wheel-boxes
PostPosted: Thu Mar 21, 2013 4:39 am
I had exactly that problem. Mine turned out to be many years accumulation of dirt, gunk, etc. in the drive system which in turn was causing a mechanical blockage of the drive cable at the wiper box wheel on the drivers side. The drivers side end of the cable outer sleeve is open to atmosphere which allows the crap to get in. A simple removal of the entire drive cable (Inner and outer) from the motor, wheel boxes, and a thorough clean and regrease. Then reinstall.
I would be doing this first, and you will also be able to inspect the wiper box wheels at the same time to determine if that is actually the problem.
You might be surprised (as I was) and a couple of hours work will have them working like new again.
Disclaimer: Mine is a 78...I am making the assumption the system is the same across the mini range.
2000 Ford Festiva 'Trio' - 26kw ATW
 Post subject: Wiper Motors.
PostPosted: Thu Mar 21, 2013 5:44 am
I can check and rebuild or supply Exchange wiper Motors for Mk1 and Mk2 Mini.
"Let us remove your "SHORTS"
PostPosted: Thu Mar 21, 2013 8:17 am
ok thanks.. i might even go to the rover wiper I have a new spare one sitting around doing nothing.
PostPosted: Thu Mar 21, 2013 10:21 am
The Rover ones look similar but are wired completely different to an Oz round motor. It's not that easy...
PostPosted: Thu Mar 21, 2013 10:28 am
it will be sweet, at the moment my has no auto return just power on & power off lol..
got to bee good when timing it to land on the right spot on the windscreen.
PostPosted: Thu Mar 21, 2013 1:12 pm
Check with Tony how to wire it. Or you might let the Lucas smoke out. :cry:
[edit] PM sent re a Clubby motor
PostPosted: Thu Mar 21, 2013 3:24 pm
My Nb Race mini had exactly the same issue (even came with a spare motor ) Bench test motor OK; in car - no go.
Clean up all the old grease and gunk.- regrease ... and now works easily.
PostPosted: Thu Mar 21, 2013 3:27 pm
Do not use heavy wheel bearing grease, it's too thick and gunks things up.
Ordinary chassis lube grease is fine. Or LMM molygrease.
PostPosted: Thu Mar 21, 2013 6:16 pm
Yes! This! Seen plenty of gears/wheels worn down to almost nothing & the cable not too flash either...
cheers,
Jacob
Users browsing this forum: Phil 850 and 88 guests
