It is currently Thu Jul 24, 2025 11:00 am
PostPosted: Fri Mar 22, 2013 4:49 pm
Just purchased a cheap AAH-OOH-GAH horn for my mini. Came with zero instructions on how to install it also. Says its for 12V 3A power so hope this will work. Has a red and black pos and neg cable and one nut and bolt. So first question. Where do I wire it to and were do I mount it? Has anyone installed one of these ebay horns? Will prob try on weekend but would like some advise before.
cheers, btw its for 98 rover cooper
PostPosted: Fri Mar 22, 2013 4:51 pm
Take the existing horn out, cut the plug off the end and crimp on new suitable insulated spade terminals. I think purple wire is positive.
Mount the horn anywhere you can - your engine bay is pretty full.
:D
PostPosted: Fri Mar 22, 2013 5:22 pm
:D
I mounted mine on my old 93 rover mini in the drivers side guard.. After i ripped the aircon out.
No space in my 97 rover but i have a Klaxon waiting to go in the moke.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Fri Mar 22, 2013 5:28 pm
Plenty of room in a 97 - I've got twin magnums in there.
:D
 Post subject: Fitting Horn on Rover.
PostPosted: Fri Mar 22, 2013 8:28 pm
Or if you want to do it properly use the existing horn wires to trigger a Relay. Feed the relay a decent 12 volt supply (Fused) and take the horn power from the relay it will work better and will not melt your horn switch.
"Let us remove your "SHORTS"
PostPosted: Fri Mar 22, 2013 8:45 pm
98 model minis were like that from factory.
:wink:
