It is currently Mon Jul 21, 2025 10:40 pm
 Post subject: Win!
PostPosted: Sat Mar 23, 2013 10:38 am
I wore my other supercrap compressor out finally after four years of slaving over a sandblaster. I had an intention of not replacing it until I get a proper large unit....but I just can't ignore 50 bucks.
Its a shop ex-display. Missing the sump plug and air filter. I am not going to worry about the filter, and I found another plug with the same thread to keep the oil in.
This will do until then.
PostPosted: Sat Mar 23, 2013 12:54 pm
nice that is a great win!
 Post subject: Re: Win!
Hey Mick, good price!... whats it specs?
Jim
PostPosted: Sat Mar 23, 2013 1:00 pm
Hi Jim,
It "Claims" 200 litres per minute free air. Not enough to run a sand blaster cabinet on it's own, but enough to use for the air tools etc that I'm using at the moment.
How's your EFI?
PostPosted: Sat Mar 23, 2013 1:10 pm
Mick wrote:
Hi Jim,
How's your EFI?
Hey Mick. EFI is just purring along. I might get some time this weekend to do some work on it as young Hamish is over in the USA with his mother.
The engine has decided to be incontinent and drops large puddles of oil (I think around the oil filter area) but only sometimes.
I've also got some electrical noise coming from the EDIS coil pack . I'll get the oscilloscope out for this... most probably needs a capacitor on the 12V rail right near the coil pack.
How did you go with the wideband AF meter?
Jim :D
PostPosted: Sat Mar 23, 2013 2:40 pm
This is totally unrelated to your original post but having a look at the photo of your S I noticed that the right hand tank has a shorter spout thing (where the petrol cap goes) no idea what its called, than the left. My S has the same and always wondered why. By the way, like the colour of the Mini, nearly identical to mine.
PostPosted: Sat Mar 23, 2013 2:44 pm
Yes,
I believe this is a peculiarity of at least some of the right hand tanks. I've seen it a few times before as well. I'm not sure if its the tank or the way its fitted, but the RHT someone fitted in time immemorial to my 997 Cooper does not have the same problem.
PostPosted: Sat Mar 23, 2013 6:16 pm
My s has a shorter neck than the other one
PostPosted: Sat Mar 23, 2013 6:17 pm
Great price on the compressor , well done
PostPosted: Sat Mar 23, 2013 6:36 pm
Rover Cooper
Kissed on the d1ck again by the lucky bastard fairy, right place right time, and able to find a use for what its not designed to do, always one step ahead and thinking outside the square.....Will you be in Darwin aroung june, I am going up to get a Darwin stubbie:'(
PostPosted: Sat Mar 23, 2013 7:04 pm
Who's to know? At this stage I don't think so.
Don't even dare to think about opening up the Darwin stubbie. They're for aesthetic use only. I'm pretty sure they will cause cancer of the stomach if you choose to drink them.
PostPosted: Sat Mar 23, 2013 7:38 pm
Rover Cooper
I just need one for a garage for the mini,
PostPosted: Sat Mar 23, 2013 7:41 pm
Rover Cooper
Wife is buyying me a 5 x 9 metre man cave for the dack yard, to keep me out of her hair since I retired I been annoying the crap out of her, hoping she would get me a new shed and it WORKED??
PostPosted: Sat Mar 23, 2013 7:53 pm
Nice one , 9x5 should fit a few mini projects in there.
PostPosted: Sat Mar 23, 2013 8:56 pm
go a meter and a bit bigger and you will be able to fit more minis in it.. I have a 7.5m x 9m wide.. Thats room for 6 minis..
Users browsing this forum: Astroblue, Bing [Bot] and 100 guests
